Question about Dryers
Two days ago, SMUD installed a Smart Meter on my home. I was unaware of the Smart Meter install and was drying a load of clothes. My electircity went off for about a minute then came back on. I went to the laundry room to restart the dryer. It would not restart. Iwent out to the breaker box and checked the breakers, flipping them several times to make sure they were on. On the way back into the house I noticed the notice from SMUD regarding the install. My dryer still would not start. I called SMUD to report the problem. Chris, the guy who did the install came back to my house and used his volt meter to check the breakers and, the outlet the dryer is plugged into. Both checked out okay. I am left with a dryer that is no longer working. I spoke with the supervisor for the Smart Meter install. He stated he would emal me a claim form as soon as he got off the phone. The claim would go before a board back in North Carolina. The board would either deny or pay the claim. It would take several months and they may not pay it. I need to find out if it is worth it to fix this dryer. It is seven years old, but the last thing I can afford is to purchase a new appliance. Is this likely some thing that is easy and inexpensive to fix?
  • 2,321 Answers
Depending what the problem is it could cost several hundred dollars to repair it. Probably cheaper to buy a new one and at least it would be under warranty
Posted on Mar 02, 2017
SOURCE: Whirlpool Electric Dryer Won't Start
Your dryer has a non-resettable "thermal safety fuse" part number 3392519 which stops the machine dead when the temperature near the heater gets too high. Typically a restricted vent system causes this so you definitely want to check that before replacing it. A failed control thermostat can also cause this so check the operating temp too.
Posted on Dec 30, 2007
exspert
  • 55 Answers
SOURCE: cloths dryer problem
ok " your dryer should have it's own line, make sure nothing else is pluged into that line.
may have other devices drawing amps.
Posted on Jan 23, 2008
  • 1028 Answers
SOURCE: Dryer stopped before clothes were dry and now it will not start again
possible bad thermal fuse remove back look for small white object on left side just above blower on side if lint screen housing with continuity checker ck to make sure there a closed connection through fuse
Posted on Jun 06, 2008
  • 9 Answers
SOURCE: Dryer won't turn on for 2nd load
A couple of things is to make sure you have 110v at the recepticle, if you do then it's with in the dryer. It could be the door switch wont close, thermal over load won't reset in your motor(if it got hot enough to open, you said it had been in use) , broken belt switch if your dryer has one, or even the thermal fuse (in series with L-1) opened up. Ohm out the door switch in the closed position, it should read 0 ohms, Same with the thermal fuse, should read 0 ohms, not an open read.Good Luck..MJE
Posted on Mar 26, 2009
SolutionGuy
  • 331 Answers
SOURCE: Dryer trips breaker after 5 minutes...BRAND NEW!!
Hi Shel,
Based on your description of the problem, I came up with a theory. Your new dryer is of higher wattage than your old one and is therefore pulling more amperage. I'd also make a bet that your dual breaker in the basement has the number "30" printed on it. Whether it does or not, your breaker should be replaced.
NOTE---> Ideally, you'd begin by removing the breakers (there are 2 of them) from the panel and take them with you to Lowe's, Home Depot or Ace Hardware and ask one of the sales associates for a 40 amp version. This way, you'd be sure to get the right ones. If you don't want to do that, then open up the breaker box and copy all the information off of the dryer breaker (also take not of how wide it is... 1/2", 3/4", etc...). Basically you'll need who made it (Square D, G.E., etc...) and how wide it is. Use this info to shop for a 40 amp version.
I don't need to tell you that working inside a breaker box can be EXTREMELY DANGEROUS if you are not careful. Here is a picture of the inside of the box, NOTICE THE LUGS AT THE TOP! THEY ARE ALWAYS "HOT" AND SHOULD NEVER BE TOUCHED!!!!!
Before you remove the panel to access the interior of the box, TURN OFF YOUR "MAIN BREAKER" (it's shown in the picture above).
Now that all of the safety stuff is covered, all you gotta do is pull the bad breaker out and install the new one! Piece of cake, really. Here's a video on how it's done.There ya go! If this has been helpful for you, please remember to rate this solution. Thanks for using FixYa!
SG
Posted on Apr 03, 2009
Last January I switched my power supplier from Click Energy to Origin Energy. Origin Energy stated that they install the smart meter for free within 8 weeks. It is now 10 months, Ron Hartmann
ring and say that tomorrow is a good day for the installation of the free meter because the next day will be a different supplier if it is not done
10 months is far too long
Nov 07, 2017 | Power Computers & Internet
I have a washer dryer combo DWC LD1013 it stoped drying. My clothes are more wet when put in to dry. The clothes would be extremely hot but all wet. It works 1 cycle and then stops. Please help ????
In order to dry cloths, you need two things, heat source and air flow. Sounds like you have heat but no air flow. If you can, pull unit out and check vent for washer. Look around unit and make sure there is nothing blocking any vents. If you don't see any thing, try drying with vent not installed. I run into a lot of homes with clogged vents inside walls. By drying with no vent installed, it might tell you if you have dryer problem or a home issue. Good Luck
May 25, 2016 | Washing Machines
Kenmore electric dryer 110.60712990 Series 70 heats but does not dry the clothes. A friend with a meter came over and said that there is 9.8 ohms resistance on the heating element. Is this within normal...
Your heating element is good. It should read between 9 to 13 ohms. If the heating circuits are working, then you don't have a problem with the heating circuits. The numbe ron cause of drye heat related problems, or longer dry times, is poorly installed, or clogged ventilation. A simple test to try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the exhaust should be forceful and warm (about 140 degrees).
If the air flow is normal, and your clothes dry normally, the problem is with your exhaust ducting from the point where it leaves your dryer to where it exits your home. I would recommend you inspect the entire length of your exhaust ventliation to make sure it is free of kinks or clogs if this is the case.
If the air flow is weak, then the problem is INTERNAL to the dryer. The most common source of the problem is a clog in the blower fan housing preventing air to flow properly. Remove the blower fan housing cover and clean as necessary. Make sure the blower fan can turn unobstructed.
Let me know if you still have problems. I hope this helps you.
Jun 25, 2009 | Kenmore 63942 Dryer
I need advice on dryer for my kitchen.
This isn't an add its two different units that I have installed and are both condensation dryers. Which in my opinion is better for your needs and lacking venting.....LG and Miele also have 15 cycle so now the decision is what your needs and Budget. Prices range from 700-1500 but well worth the money. Bosch Axxis Condensation Dryer (model: WTMC8320US) you can machine-dry clothes without venting hot, moist air (or indeed any air at all). The Axxis Condensation Clothes Dryer condenses the moisture in the hot air to water and releases it through the water the need for ducting and a blower motor to help expel hot air. Ventless dryers make installation easy, fast, and very cost effective. And since little heat is lost when the air passes through the condensing chamber, it takes very little energy to raise the temperature back to optimal drying levels, thereby saving you energy. The Bosch Axxis ventless dryer features the unique DUO TRONIC system with 11 auto dry cycles that tailor the drying cycle to your clothing. And Bosch's exclusive DUO TRONIC system combines two moisture and three temperature sensors to automatically deliver precision drying. This machine virtually operates at the touch of a button to prevent over drying and damage to your clothes. With the stacking unit I think this is your best option due to keeping moisture, and later mold problems due too condensation. The Ariston Stackable Condensing Dryer ASL75CXSNA is the perfect choice for any home lacking venting capabilities and is the largest condenser dryer on the market, bringing the convenience of a compact laundry system to any home. Wrinkles are minimized with the innovative Pre and Post CreaseCare feature - periodically tumbling the clothing until you come back to remove it - and the handy Bidirectional Rotation of the stainless steel drying drum. Clothes gone musty from long closet stays can be quickly and easily refreshed with the ASL75CXSNA using the intuitive Air Fluff cycle, and the 12-hour Delay Timer allows for freshly-dried loads at your convenience.Key features include: spacious 16-pound load capacity; 180º reversible full metal door; removable lint filter; included stacking kit; Easy Iron option; and electronic Sensor Controls. The Ariston Stackable Condensing Dryer ASL75CXSNA has the high class, top performance, and compact convenience to be a welcome addition to any energy efficient home.Note: This item pairs with the matching Ariston Stackable Washers. I hope this was helpfull~ Have a good day
Feb 05, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Clothes smell.
Mold, mildew and other fun things use washers as a breeding ground. Clean your machine with a generous amount of white vinegar run through a cycle. Or there is a product called Affresh you can buy at Lowes or Home Depot.
Jun 21, 2008 | Asko W6221 Front Load Washer
Dryer will not dry cloths
make sure that the dryer has the proper voltage going to it and if it does then check the heating element and the safety on the left top of the element housing
Apr 18, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
79 people viewed this question
Top Dryers Experts
