Antenna cable broke on TV - Televison & Video
    President:
  • Televison & ... Master
  • 775 Answers
There's no question in that statement. Even as a statement it does not give any detailed information that would help provide help.
Posted on May 22, 2011
Looking for cable with analog on one end and coax on other end
Since you're going to be soldering anyway, these are available on ebay. Just keep your wire as short as reasonable.
The other way is just grab a short f-type to f-type coax (standard TV coax cable) , and cut off one end. Then unweave the shield and solder into a bundle with a short wire to the TV antenna ground.
Sep 11, 2016 | Westinghouse Televison & Video
Antenna in port connection broke off the tv
You can purchase the whole main pcb for the tv, but this would be costly with arts and abor. You could order just the part you broke called the Tuner but, you would need to know how to solder to take off the old and put on the new one which is time consuming. The cheapest and easiest way is to if you do not have cable or sattelite and just have an over the air antenna, get you a converter bx with the composite outputs "red,yellow,white" and connect that to your tv. Thats the cheapest and simplest work-around fix. Good luck!
Jun 29, 2012 | Sylvania Televison & Video
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
No signal on samsung 40"lcd tv
IF it is an ATSC tuner ,newer type ,( digital tuner) it needs better antenna, most importantly Check the cable from Antenna to the connector. using multimeter , put on resistance ,any, anc check both ends of the cable, when there is no change on the multimeter consider the wire is broke somewhere. Make sure the antenna is pointing towards the tv station. also check www.antennaweb.org i think to see the DTV channels in your area. GL
Apr 08, 2010 | Televison & Video
The coaxial cable antenna broke on my RCA tv
The part is called a Female Belling-Lee Socket. Radio Shack, or anywhere that sells antennas, CB radios, repairs TV sets, should have one. Soldering it in, is another matter. Be careful.
Feb 04, 2010 | RCA Scenium D40W20 40" Rear Projection...
Antenna/cable socket
yes it can be repair..You would have to take it to a repair center so they can repair it for you..
Apr 24, 2009 | Panasonic PV-C2541 25 in. TV/VCR Combo
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
ANTENNA TERMINALS
you need to take off the antenna so that can solder the antenna terminal inside the tuner.
Oct 02, 2008 | Samsung SlimFit TX-S2783 TV
Cable plug broke off
Well first repair the coaxial cable going to your antenna. There is no way you can use RCA cables as a substitution for coaxial cable. They have totally two different properties. You can use the coaxial and feed it to a VCR/DVD player where you can output the signal with RCA/composite cables. Basically, use your VCR/DVD player as a tuner for your TV.
Sep 20, 2008 | RCA D56W20 56" Rear Projection Television
Need an antenna block for a Sanyo DS25390
Was the block a cube about 1" ? You should be able to salvage one from an old tv. This block is used to isolate the antenna/cable from the "hot" chassis inside your tv. If you should find a used block ,make sure it does this. If you get one that gives you a direct connection to the chassis, your antenna/cable connector would give you a shock and probably burn out something in your tv when the cable is connected. Some of the Sanyo's have this connector made on to the tuner. If this is the case you'd have to either put a new coax connector in the tuner OR replace the tuner. Stargazer
Jan 23, 2007 | Sanyo DS25390 TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
