Question about Motorola Cell Phones
The phone doesn't ring, even though the ringing volume is set on number 7. The phone doesn't beep when a text message is received.
  • 48 Answers
Maybe your phone have drop somewere. you need to open it to check the buzzer for problem.
Posted on Aug 15, 2008
SOURCE:
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
My phones ring style is set to loud detail and volume is at the highest being 7,when I recieve a call it is silent?
Hi There,
As per my understanding you have set your ring style profile to loud and highest volume 7 but still ur phone phone rings on silent when someone calls..
Please change the Profile setting once again as mentioned below:
How to change call alerts and styles?
1.From the general menu, select "Settings" > "Ring Styles" > "Style Detail"
2.If you select one of the styles, ie. "Loud" you can then highlight by scrolling down on the wheel & select "loud detail" & press on the "change" button (top right corner key).
3.Here you will be prompted to change any feature available to the "loud" style: volume, ringtone, alerts, voice mail, text messaging sounds, reminders beeps etc etc. All you need to do is to select the feature you need to change with the directional wheel and press the "change" button for each.
If you think my solution helped u to resolve ur issue please do vote for me..
Thanks
Enjoy!!!
Oct 28, 2010 | Motorola Mobility RAZR V3
My daughters cell phone will not ring. It has the "bel" crossed off on the front screen. How can I fix it?l
It is set on silent mode. In you phone settings, you'll need to change from silent to ring. Not sure how to get where you need to go with the model of phone. But this is a settings issue not a hardware issue. Just look though the phone settings menu to find the proper selction.
Sep 30, 2010 | Samsung Cell Phones
Phone is not ringing/beeping even though it's set to
try to clean your phone buzzer connection ,if no luck replace it...much better if you go to a certified technician to repair it..thanks
Jun 09, 2010 | Samsung Rant Cell Phone
My motorola pebl phone will not ring
Hii
can u plz chk and tell me if ur profile is set into vibrate mode? and regarding keys, u can set the key tone volume to zero.
if ur a new user here is wht u hav to do
> MENU > RING STYLES > Change it to LOUD or VIBRATE and RING
Regards
Hope it helps u
Sep 11, 2009 | Motorola Cell Phones
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Cell Phones Logo
71 people viewed this question
Top Motorola Cell Phones Experts
Ekse
Damen Wong
Damen Wong
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
