Question about Dryers
The dryer is getting the clothes hot, but not drying. What causes this problem? Thanks
    President:
  • 3,074 Answers
Venting issue, you can disconnect vent tube and run a load of clothes if it dries then it is the vent tube, if not then the dryer will need disassembled and all the lint clean out from the lint trap to the end of the dryers vent tube, if is recommended to clean the lint out of the inside of the dryer at least once a year, varying on usage, and the lint screen each time before/after use. Hope this helps Tim
Posted on May 22, 2011
  • 3,018 Answers
  • This is caused by a lack of air flow. Check the vent trap that is suppose to be cleaned out every time. More importantly either your vent hos is somehow clogged or pinched so air cannot escape of the vent for the dryer going out through your roof is clogged. This happens from time to time. That vent pipe should be cleaned out every year or so to prevent a complete clogging. If you don't take care of this you risk a fire in your home because things will continue to heat up but with no air escape you will have combustion in the near future.
  • You can hire a service to do this.
  • Or you can get an air compressor with a long hose and an blower attachment. Unhook the hose from the back of your dryer, find the pipe and blow the heck out of it untill you confim it has been cleared.
  • One way or the other you need to address this ASAP.
Regards, Tony
  • Iron
    Iron May 22, 2011
    Also when you remove the hose from the back of the dryer, turn it on and feel for a rush of air. If you feel a rush the issue is in the house venting. If not it could still be the venting but the dryer itself needs cleaned as well. Any questions or comments feel free to leave them here.
    Regards,
    Tony
4 Suggested Answers
Vish2
  • 74 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Posted on Oct 11, 2007
maklean
  • 1665 Answers
http://www.repairclinic.com/0088_8_1.asp
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
localwonder
  • 6784 Answers
SOURCE: Dryer gets hot, but not drying clothes
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
4. Moisture Sensor
Most units will have a moisture or dryness sensor as well that will fail. inspect the sensor for faults. replace if necessary.
Posted on Sep 05, 2009
The dryer heats up,it also goes through the entire cycle but the clothes are never thourly dryed.What could be the cause?
Typically it is because lent has built up in the vent tube. Here is a good site that shows you how you can do it yourself: http://www.wikihow.com/Clean-a-Clothes-Dryer-Vent
Sep 04, 2014 | Kenmore Dryers
I HAVE A HE3 DRYER HAD TO REPLACE THE THERMAL FUSE AND THE THERMISTOR, DRYER STARTED FINE DRYED ONE LOAD AND BACK TO NOT STARTING THE CLOTHES SEEMED HOT WHAT WOULD CAUSE THESE TWO FUSES TO GO. THE AIR WAY...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Mar 27, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer won't get hot enough to dry clothes
mAKE SURE THE VENTING SYSTEM IS COMPLETELY CLEANED OUT. a MOISTER SENSOR DETECTS ANY BUILD UP OF LINT CAUSING TO KEEP THE HEAT IN CHECK WHICH TAKES LONGER FOR THE CLOTHES TO DRY
Jun 13, 2010 | Hotpoint NBXR463EBWW Electric Dryer
AF Code flashes briefly; Clothes don't dry - vent clear
Remove the back of the dryer and chek the lint filter area from the lint catching filter to the exhaust tube. There is a blockage in airflow even though you feel the air at the exhaust there still insn't enough air flow to allow the proper drying of the clothes. This symptom that you gave clothes being hot but not dry the only cause for this is improper air flow
Dave
Mar 31, 2010 | Dryers
My dryer runs and gets hot but cloths don't dry.
Your problem may be attributed to a clogged exhaust system (e.g.: clogged inside the dryer's vent, flexible vent behind dryer clogged and/or clogged inside wall, etc.).
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Open Questions:
Dryers Logo
109 people viewed this question
Top Dryers Experts
