My washing machine completes all the functions except the rising process. In order to discard the water I have to connect it directly with the pump. I tried changing the control card, but the rinsing process does not seem to work.
  • 10,319 Answers
Since the pump drains out after the wash cycle that means the pump is fine
The control timer for the rinse cycle drain is at fault. If your washer has a digital control you will need a new circuit board. If you have the old standard type with a dial you set the timer behind that dial needs to be replaced
Posted on May 22, 2011
When filling the drum the water drains out with switch not in drain position. and drain pump not running?
Rise you drain tube/hose from the floor. Where the drain hise goes out of the machine, rise it up to the height of the machine. Then connect it to the drain pipes
Feb 17, 2016 | Washing Machines
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
F 02 was flashing and the water is still in the machine how do i get the water out
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Take care of lot of water going to the floor, unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Jun 20, 2010 | Kenmore Elite 45986 Front Load Washer
My lg 7KG 1405F model in does not complete the washing cycle stops at rising (oe) is the code
OE is drain error, which means that the machine has detected that the water level is not lowering quickly enough...Probable cause is a blocked pump filter...Check via small door at floor level..Unscrew pump cover and clear filter....Remember that all water will drain from this point, so drain machine first...Leaning the machine back can help...Good luck....Nomess
May 20, 2010 | LG WM-1480FHD Front Load Washer
I have a Simpson Eziset 750 washing machine.
Most washing machines have a length of clear tubing external of the drum assembly (inside the housing). One end connects to the lower section of the drum, allowing water to enter the tubing. The other end of tube connects right up to the top, and usually inside the back panel (where all electrical wiring is) This end is connected to a pressure switch..As the water begins to fill the machine, it also rises the same height in the tubing.The tube is now sealed at both ends. The rising water creates air pressure inside the tube, activates the pressure switch and via electrical contacts closes the water inlet valve(s).
Oct 08, 2009 | Washing Machines
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Mar 13, 2009 | Washing Machines
Front loader washing machine is not draining
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Be prepared to catch lots of water. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Jun 29, 2008 | Whirlpool Washing Machines
Flashing F and alarm
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.... Hope this helps
Jun 08, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Simpson enduro 751 clothes washing machine
Befit Sports are the suppliers for motocross gear, enduro clothing, ATV apparel, dirt-bike clothes and moto gloves.
Visit our web site http://www.befitsports.biz
or
contact us at info@befitsports.biz
Apr 06, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
