Question about Garden
Bought this lawn mower.It was sitting for two years and now it won't start.
    President:
  • 3,074 Answers
First things first:
1) make sure that the kill for the magneto/coil is breaking contact( it is on the side of the mower,follow the cable down from the red bar)
2) gas to carburetor
3) spark to plug/s
4) gas to cylinder/s
pull plug and try starting mower, observe spark plug for spark and fuel coming out of cylinder/s. if spark no gas, then check to see if it getting to the carburetor, if it is then it is the float and seat in the carburetor and will need to be cleaned/replaced/rebuilt. Or just simple pour gas into the carburetor and try starting if it starts then it is the fuel line, carburetor. Hope this helped Tim
Posted on May 22, 2011
1 yr old -won't start this year
probably need to clean out carby and fuel tank
Jun 11, 2013 | Toro Power Lawn Mower
Mower Won't Start
Check your start 20-30 amp fuse, Should be on right side of motor, sitting on it.
May 29, 2013 | Craftsman 46" 21 hp Lawn Tractor
Honda Harmony II HRR216 won't start
Check for spark of smell of gas on the plug when you try to start it. That will tell you if it is fuel or ignition
May 18, 2013 | Garden
Lawn mower won't start
Take Breather element off,and try to start it Then or if it starts that way cut it off and replace the breather and if it doesn't start You May need to change spark plug also, As if You have flooded it, Gasoline will kill a spark plug
Mar 27, 2013 | Garden
Hu700f won't start
My huskuvarn will not start put a new carburetor and a magnitude coil on it it is brand new and will not start it is a 700f husqvarna any suggestions on it plus like I said a new coil and it is not sparking and not starting please help me out
Feb 18, 2013 | Husqvarna HU700F 160cc Gas 22-in 3-in-1...
My poulan pro lawn tractor won't start. when i turn the key it click's 1 time can you help ?
Have you checked the battery terminal connections? Is the battery charged fully? Are you sitting on the seat when you try to crank the mower? Could be any of the above but most likely battery connection or the battery is discharged or old.
Aug 20, 2012 | Poulan Pro Lawn Tractor 2006 and Newer...
Troy-bilt 550 series mower won't start. I've only used it twice.
does it crank over?did you leave the blades on?are you pushing on the brake pedal
May 25, 2012 | Troy Garden
John Deere LA145...it will fire up and immediately die and then won't start again. What should I do?
Usually this symptom means a clogged filter, gas tank outlet tube is plugged or a clogged needle valve. But if it smells gassy it is probably not starving, but may be running too rich. If it does not smell gassy then it's probably a fuel delivery problem. Sometime rubber fuel hoses can swell up inside and restrict flow.
Apr 14, 2012 | Garden
I bought a craftman lawn mower 6.75hp. I only used it twice, and then I let the lawn mower set in my garage for about 6 years, with the gas and oil in it. Now it won't start, and I did get it to start...
If it has been stood with the same fuel in it for any lenght of time, then the fuel will go bad, drain the fuel and re fill with fresh fuel, if there is a bowl drain on the carb slacken this and drain the bowl, now try again, if it does not sort itself out after a lenght of running then will need to remove the carb float bowl and blow an air line through the jets.
Feb 29, 2012 | Craftsman Garden
Garden Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
