When i tried to set up the receiver i can not get the remote to work it just shows the dvb screen and i can not get to the menu. i have changed the batteries. i have not used this box for a long time as it is int another room and needs retuning due to the switchover
    Brigadier General:
  • 8,546 Answers
Have you looked at the manual?
The specific product you're inquiring about is not showing in your post. Name the make and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Google search: "(product) manual"
If you think the remote is malfunctioning, read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Or look on eBay, usually much cheaper if available.
Posted on May 22, 2011
The Bravia menu comes up across my screen. It will go off when I hit any button on the remote & then come back on. the model # is KDL-32EX301. How do I get it to go away?
It's caused by the Bravia Sync feature. It doesn't always connect correctly. When there are issues then attempts to sync up cause the menu to appear.
The solution is to switch off Bravia Sync.
Go in to the TV's set-up menu, and choose HDMI Set-up.
Scroll down the menu list and choose Control for HDMI, then set the menu option to OFF
Let us know if that fixes the problem for you.
Sep 15, 2014 | Sony BRAVIA KDL-32EX301 32" LCD TV - 16:9...
Bell expressvu receiver
If you are using the OEM Bell remote to control your Bell receiver, the remote may have failed.
Jan 17, 2014 | Televison & Video
Dish remote 2 changes channels on both tvs and dish remote 1 changes channels on both tvs
Is the receiver in dual mode? Go to the receiver, open the door, and hit the mode key. If both TVs are still showing the same thing, then the issue is not the mode.
Go to TV 2 (the one without the receiver) and make sure the TV is tuned to channel 60 or 73. If it is still showing the same thing, go to TV1 (the one with the receiver) and hit Menu, system setup, Installation, modulation (menu 6-1-5). make sure the modulation for tv2 matches which channel you put your tv2 on.
Still showing the same thing? check the back of the receiver, the RCA cables (red/white/yellow) are plugged into the TV1 ports not the TV2 ports.
Showing different things but the remote still changes channels on both tvs? Go to TV1, hit menu twice, near the bottom there are two boxes each with a number. This is the address for each remote (tv1 and tv2). On the TV2 remote hold sat until it stays lit, choose a number different than on the screen, touch pound (#), the sat light blinks three times, hit record, the number on the screen should change to match the one you typed in.
Still being silly? Call a priest, you have a poltergeist!
Oct 24, 2013 | DISH Network IR Remote Control
How do you tune in a sense 51 - 19dvdw tv to channels
First check your aerial.
If other devices such as PVRs or other TVs can receive a signal then the Sense 51-19 should be OK also
Turn on the TV.
Press the "TV/.AV" button until the letters "DVB" (Digital Video Broadcast) appear on top right of screen.
Wait until patterned blue screen is displayed and the message "No Signal" is shown.
Press "SYS MENU" 3 times
"General Menu" should be displayed with Language option in highlight.
Press the "CH+" button once to move the highlight to the "Reset" option.
Press the "TV/TXT-DVB MENU" (this has the letters "SET" engraved on the button itself.
The TV will mute and a sub-menu will be displayed in the top left of screen.
Use the "CH+" or "CH-" to scroll to the desired option.
Cheers
May 23, 2012 | Televison & Video
I've BD 512 universal remote control,and i need code for Durabrand DVB-T CG5660-M digital set top box.Please help!!!
i need code for a durabrand dvb- digital set top box me remote is a bd-512 universal remote control
Jan 14, 2011 | Audio Players & Recorders
I have a Alba DVB-T set top box wont change channel
I think you most likely have a failed box problem.
Feb 17, 2018 | Televison & Video
Hi I have a KROSS TS- 2818 DVb-T/dvd combo player that the remote has died on. This means that the unit is stuck on DVB and I am wondering if anyone knows how to manually change the unit to DVD. Have tried...
Not sure about manually changing from DVB to DVD but you could try and get the remote working first by pulling the remote apart and removing the red infared plastic part at the front of the remote, install new batteries and see try it out. Have seen this work on other remote units.
May 02, 2009 | Televison & Video
Screen is to big
Either the TV or the cable/satellite receiver has Zoomed in to the image when parts of the picture are cut off. Look at both remotes for a Zoom feature or the onscreen menu's for any settings. Usually TV settings don't change on their own but cable/satellite receivers can receive updates and it may need to be reset afterwords, much like a PC.
Oct 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
41 people viewed this question
 Grubhead
Grubhead
