Question about Pool & Spa
I have a 1.5hp Proline PE71-11-H Pump. When I turn it on the water comes out of the return in the pool like a rocket but within seconds there is little to no pressure coming out and almost nothing being drawn in to the skimmer basket. There is no apparent leak other than a drip every 5-10 seconds coming from the pump itself. Does the pump need to be replaced?
    Guru:
  • 610 Answers
Try to check if the connections were touching. Open the motor then tape the connection to avoid short circuit. Also, you might need to check your wires if they are enough to handle the current. Check the temperature, are the wires getting hot? do you have proper grounding?
Hope this helps.
Posted on May 22, 2011
Google com
put a ball valve on line we do that all the time to fix a leaky multiport
Aug 15, 2014 | Hayward Pro Series 18" Above Ground Pool...
How do I get into the filter to check backwash valve?
you shouldnt have to go inside the filter that is done in the multiport
turn system off turn multiport to backwash till water comes out clean shut off then turn lever to rinse for about 30 seconds turn off pump again turn lever to filter you should see more water pressure coming out of pool return
Sep 10, 2013 | Hayward Pro Series 18" Above Ground Pool...
Can't get impeller off proline pump
backwards thread screw then impeller turns off regular if you hold back of motor
Jun 16, 2012 | Hayward 1 12 Hp Super Swimming Pool Pump...
I purchased and installed this model pump (FPOS1790PCA). The first couple of times there was water on the pool cover, the pump seemed to work fine. I have several inches of rain water on the cover...
You may want to check with Flotec first since many of the manufacturers handle warranty claims directly instead of the store being involved. If the unit falls within the stores return period then just take it back and excahange/return it...if not, Flotec is at: http://www.flotecpump.com/ResidentialContactUs_ContactUs.aspx
Select warranty from the drop down menu and go from there.
John
Apr 19, 2011 | Flotec 2115 Swimming Pool Cover Pump...
Proline pool pump SD-1--1N11XB
This sounds like you have a bad seal in your pump and the loose piece is probally a piece on the shaft of the motor called a water slinger. This is just there in case your seal goes bad and leaks water it will spin with the motor and sling the leaking water out and away from the motor so a small leak does not ruin your motor. But you will still need to replace your seal and "O" ring.
Sep 12, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pool pump intex 51 pumps water but return flow is low
if you cartridge is completly clean then start by disconecting the out tube that goes to the pump housing
sometimes debris gets caught there entering your pump.
a little hair causes other things to back up
once you are satisfird that those 2 things are ready then close it all up and open the bleeder cap on top of the cartridge holder
Now let water in from the suction side
when water starts coming out of the bleeder cap then open the return side
Now turn on the puimp
let it run for 20 seconds and then close your bleeder
Should be working fine after that.
dont forget to leave the bleeder cap alone on the bottom of the canister unless you are draining the water from the canister to clean it. As soon as you are done close it back up
Jul 15, 2009 | Intex Plunger Valve & Straniner Basket set...
Air in filter on hayward above ground pool.
I had similar situation.try removing winterizing plug,wrap with teflon tape, make sure no debris on threads. This worked for me. Tony
Apr 28, 2009 | Pool & Spa
Pool & Spa Logo
405 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
