Question about Bosch Classixx WFL 2066 Front Load Washer
MY WASHING MACHINE A CLASSIX 6 1200 WAE24363GB IS FLASHING F-21 ,WHAT DOES THIS MEAN?
  • 1,116 Answers
F21 means motor or control board fault. Usually its the motor. If you have replaced the brushes and it doesn't work then its most likely the motor is faulty. Not a cheap fix.
Posted on May 22, 2011
    President:
  • Bosch Master
  • 662 Answers
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on Jun 25, 2014
What type of bearings do I need to repair a Bosch Classixx 6 washing machine Serial No. e-nr wae24363gb/05 fd8901 602075
all bearings have their identification numbers etched on the sides of the bearings
you will have to get the old bearings out and take them to a bearing shop to get the same bearings
or you could simply buy the bearings from a bosch service agent or parts shop
Dec 28, 2016 | Bosch Washing Machines
Washing machine bosch WAE24363GB basket does not rotate or spin
Or belt drive is off, or the timer has a problem or a capacitor motor is defective or the brushes of the motor in one of these four parts is the problem
Apr 16, 2016 | Bosch Washing Machines
My bosch classix dryer is saying container is full but its not and machine keeps turning off. Any suggestions?
Owner's manual no manual? Try MFG website or email their customer service, or try
manualslib.com
What does container mean? Water condensate bucket? or similar?
Apr 12, 2015 | Bosch Washing Machines
What does the error code F 21 mean
F 21 indicates a drain problem.... mostly due to a clog. Google
washing machine F 21 code. There are many links including
repair videos. Good luck to you.
Regards,
Dennis
Oct 06, 2014 | Washing Machines
Bosch classix water won't drain
check for blockages in the outlet pipes, filter and pump.
Dec 30, 2012 | Bosch Classixx WFL 2066 Front Load Washer
F-21 on a Bosch 1400s- what does this mean
F21 Motor fault. Call customer service. (NOTE: if the motor brushes are worn, these can be replaced by a competent person).
May 20, 2012 | Washing Machines
Bosch washing machine classix 6 Stopped working. wont let me program it. A key symbol flashes on
I believe that the key symbool indicates that the machine cannot lock the door. Sometimes the result of a slightly sticking door interlock mechanism. Open the door and close it hard and firmly (slam it a bit, but don't get silly about it!). A good test to see if this is the problem is to attempt a program with the door swinging open. If the symptoms (flashing key) are the same, then the issue is almost certainly narrowed down to that door lock mechanism.
If this fails, unplug the machine from the main power source and leave it for 20 minutes to allow it to reset its self, then try again.
Jul 11, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
May 28, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
844 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
