Question about Haier HLP140E Electric Portable Dryer
I own a dryer model #HLP140E and I need to buy a replacement filter that fits inside the unit. Please direct me to wear I can buy replacements. Thanks!
    President:
  • 3,074 Answers
EBay:
http://shop.ebay.com/i.html?_nkw=+Dryer+filter&_sacat=0&_odkw=Haier+Electric+Portable+Dryer+filter&_osacat=0&_trksid=p3286.c0.m270.l1313
repairclinic:
http://www.repairclinic.com/Haier-Dryer-Filter-Parts
Posted on May 22, 2011
Where can I view a video showing how to replace the black belt?
Go to www.repairclinic.com and enter Haier HLP140E to see an illustrated list of common replacement parts and perhaps view a general video showing repair.
Feb 24, 2016 | Haier HLP140E Electric Portable Dryer
PUTTING FAN BELT ON THE HLP140E DRYER
Remove the lint trap. And bolt behind it. You can then move drum or lift out to get ar screws on crossbar
Apr 15, 2014 | Haier HLP140E Electric Portable Dryer
Dry screaks really loud when dryer is on
Hi leroy schooler
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Oct 08, 2012 | Haier HLP140E Electric Portable Dryer
Any substitute for the wool pad filter that goes behind the filter in the Haier HLP140E dryer? Filters are $6 + shipping and they seem to last only a couple months. Any suggestions on how to clean? I know...
I don't have a substitute but I do find using tape rollers which I buy in bulk from Costco do clean the filter fairly well. You do have to use several sheets but it saves on wear and tear of washing it and less time waiting for it to dry as well.
Nov 23, 2011 | Haier HLP140E Electric Portable Dryer
Haier HLP140E Electric 110V dryer exhaust filter.
I have had this dryer for 4+ years and finally have used the "floor vent" filters that come 12" x 4" and cut two of them to fit. It's a pain because unlike the round design they can "fall out" when you snap the filter back in. Be that as it may, they work well because you cannot buy the black round wool filter anywhere.
Jan 03, 2010 | Haier HLP140E Electric Portable Dryer
My portable haier dryer (HLP140E) has a bad odor. I got it brand new from Walmart. It was happening with the portable washer (Haier HLP21E) too but that has seem to have faded. I've used the dryer a few...
No any smell coming from a dryer is not "normal," no matter what anyone tries to tell you. I would seek a replacement model immediately. You are not the first to complain about this model. Likewise, I would seriously consider a replacement for the washer as well, even though the smell has diminished. I hope this helps and good luck!
Nov 11, 2009 | Haier HLP140E Electric Portable Dryer
Haier HLP140E Electric Portable Dryer Logo
296 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
