Question about Dell Inspiron 1100 Notebook
No boot weird lights
Hi I have a L 1100 that will not bot or make any attempt to. Here is the weird part if I tap around to the right of the start button with my finger an amber light will flicker.If I hit both sides of the palm rest on the bottom 2 green lights flash. In both instances there is no attempt to start.
Any email advice is appreciated and welcome. I alway have problems trying to get back to thewe forums. Thank you
    Problem Solver:
  • 10 Answers
May be more than a loose motherboard dc jack connection, probably a more serious problem with the motherboard itself. Perhaps an issue with memory, try only one memory module at a time, trying one slot at a time.
Posted on Nov 15, 2008
    Genius:
  • 2,028 Answers
This sounds as though a connection has come loose on the motherboard. Open the machine and check all connections.
Posted on Aug 20, 2008
SOURCE:
Please help unlock my lumia 610, it keeps asking me for a 4 digit password. i bought the phone second hand from a street seller. my country currently does bot have many internet modes of payments.my IMEI...
You'll need to reset phone. Turn off your phone. Hold Volume Down + Power + Camera until phone vibrates and NOKIA logo appears, then release Power button but continue to hold Volume Down + Camera until boot completes. Your Lumia 610 has been hard reset. All data will be lost! On the Start screen, tap . Tap Settings > about phone. Tap reset your phone, and then tap yes.
Nov 04, 2013 | Nokia Lumia 610 Unlocked Black
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
My dell laptop inspiron 1100 won't start up. When I turn it on it go's to a screen that says it's now installed firmly in to the port bay and I can't get past that screen. I've tr
Turn off the computer. Hold the Fn key and power key to boot the computer in diagnostic mode. Follow the onscreen instructions to see if you have any hardware issues. This sounds like bad sectors on the OS boot partition.
Jun 28, 2017 | Dell Inspiron 1100 Notebook
Can't boot from usb drive or usb cdrom Tendai
Try to get into the BIOS - when computer first starts a message bottom left will show.... press F1 to enter Set up it migght show esc F1 or F2 or something like that . Whatever it is - Tap that key AS SOON AS YOU SEE THE MESSAGE. - you may have to have one or two attempts you may be lucky and get it first time.
In BIOS go to the BOOT screen - (usually right arrow key to get there) Usually the top item is "Boot order" highlight it and tap the Enter key
Hilight the CDROM line and follow help file on the right ( maybe F5/F6 to move up/down) move cd to top line... this is the 'boot from' line
Note - to boot from USB stick - it MUST be in place BEFORE you go into BIOS - hilight the USB Stick and move that up to the top.
Tap the F10 key then Enter to save and exit BIOS.
Tap the enter key when "hit any key to boot from CD" appears
Done.
Cheers.
Aug 03, 2010 | Sony VAIO VGN-FS8900 Notebook
No starter engagement 2005 Silverado 1100
I would seriouly look at the starter clutch, the 1100 yamaha cruiser motors are notorious for this problem way back when the same motor was in the viragos and the xvs 1100 vstars, yamaha have tried to fix the prob over the years but stillhavn't got it right. if it just spins and whirs without engaging the engine, but sometime will kick in engagement, it sounds like your starter clutch is on it's way out. they cost from yamaha around $450- 500 ea plus around $350 to fit you have to include a $30 gasket in all that.
Feb 13, 2009 | 2005 Yamaha V Star 1100 Silverado
Yamaha V-Star 1100 won't fire up
Check your battery connections. One or both could be loose or corroded. Most likely loose. You would still have power to your lights but too many amps for the starter to work with loose connection...
Jan 19, 2009 | 2001 Yamaha V Star 1100 Classic
Tapping noise mitsubishi 3000 GT
is it full of oil cause the oil might not be getn around the engine fully when its on a cold start
Sep 23, 2008 | 1994 Mitsubishi 3000GT
Acer 7520 does not boot
Find out if your computer's processor is X86 (32bit) or X64 (64bit) then use the right "bit" installation CD.
Sep 20, 2008 | Computers & Internet
Dell Latitiude 1100 Will not boot has poweron issue
I also have a dell inspiron 1100. It seems that it has overheated, and your motherboard or CPU has fried, or died from the heat. What you say sounds like a motherboard failure
There is currently an ongoing lawsuit. Also, take my advice, and instead of trying to fix it, you're better of getting a new computer, as the dell is getting old anways. I spent some extra cash and got myself a vaio.
Aug 15, 2008 | Dell Inspiron 1100 Notebook
1100 lcd problem.
most nokia phones have the lcd screwed against the board and they are connected by a little grey sponge thingy that presses against it and is right behind the lcd.
if the lcd is doing weird stuff like dissapearing half or fading out and in this connector is your problem sometimes taking it out cleaning it a bit or turning it around helps.
Aug 04, 2008 | Nokia 1100
Dell Inspiron 1100 Notebook Logo
42 people viewed this question
Ekse
Clive
Clive
