Question about Microwave Ovens
My zanussi fridge freezer green light is flashing but the fridge and freezer is working perfectly last night i turned it off untill the compressor was cool down but when i on it the green light start again flashing and i can hear a sound after few secound from the back of the fridge
jumptrout51
  • 3361 Answers
SOURCE: coldspot 106 temp controller working/then
Your cold control(thermostat) is bad and needs replacing.
Post a model number and I can suggest a part for you.
Posted on Oct 17, 2010
heatman101
  • 43501 Answers
SOURCE: Hi. I have an Amana/Maytag
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 25, 2010
  • 582 Answers
SOURCE: The fridge section of my
IF THE COMPRESSOR IS TO HOT TO TOUCH WITH YOUR HAND MORE THEN LIKELY THE REED VALVES IN THE COMPRESSOR ARE PASSING HOT GAS BACK INTO THE COMPRESSOR AND HAS DAMAGED THE UNIT. MY ADVICE IS TO LOOK ON TOP OF THE COMPRESSOR GET THE MODEL# & SERIAL # & MAKE AND LOOK ON LINE AND GET A PRICE FOR A NEW COMPRESSOR, PENDING ON MAKE AND MODEL THEY RUN AROUND 3-4 HUNDRED DOLLARS JUST FOR COMPRESSOR INSTALL CAN COST MORE THEN THE COMPRESSOR UNLESS YOU KNOW SOME ONE WHO HAS THETOOLS TO DO IT RIGHT
Posted on Feb 05, 2011
heatman101
  • 43501 Answers
SOURCE: I have LG fridge freezer
Many times the problem is that because the freezer is already cold the fridge will take a LONG time to recover...give the fridge a day before getting concerned about it...
If it still is not getting cold enough then moisture from the outside air may have caused the coils to freeze up and you may have to manually defrost the coils in the freezer as they may not completely defrost on the normal defrost cycle..
heatman101
Posted on Mar 08, 2011
  • 38 Answers
SOURCE: ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Posted on Nov 02, 2012
Zanussi freezone fridge freezer
Try adding freeon made for refrigerator. Can get at any hardware store. Hope this help.
Sep 09, 2013 | Microwave Ovens
American fridge freezer power on lights on in both sides. Set to maximum cold setting but freezer temp is only just lower than fridge, which is not as cold as it would normally be.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Sep 10, 2011 | Bosch Microwave Ovens
FRIDGE button is set on 3, red light flashes, air system works but it is not cool for at least 1 hour, Freezer set on 4 S and works.
Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermistor and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it. Then make sure all the vents are clear and not being blocked by food cartons. One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
New link from Appliance Repair Aid on how the wiring circuit works for a frost free fridge, the link is here.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. and the rest are bare is an indication of a system problem
If you find this helpful, a vote with the thumbs up would be appreciated for the free advice
Jul 13, 2011 | Microwave Ovens
We have a frigidaire model number frt045gb upright freestanding fridge and the light is on inside but the motor isnt running,it is warm in the freezer and fridge part
Since the light comes on, but nothing else runs, check the defrost timer. If it is stuck in the defrost cycle, the light will come on, but nothing else works.
BGA
Apr 19, 2011 | Microwave Ovens
My fridge frezzer is not working my frezzer has defrosed with out me turning it off the light is on in the fridge but the fridge aint working eaither what could be wrong with it plz help me
heatman101
Mar 25, 2011 | Microwave Ovens
The fridge section of my Candy CPCA270FFK frost free fridge freezer is cool but not cold whilst the freezer section is warm. The appliance is silent, the compressor is very hot to touch and the control...
Feb 05, 2011 | Microwave Ovens
Maytag Bottom Freezer Fridge only a few years old was replaced to sell the house. We just bought our house, moved in and the dishwasher wasn't working so we got a new one. Now our fridge is humming and the...
Refrigerator
heatman101
Feb 03, 2011 | Microwave Ovens
Hi. I have an Amana/Maytag Fridge. Model ABD2233DES bottom freezer. The fridge was working fine, then it seemed like the compressor or motor started to make a funny noise. Like it was working hard or...
Refrigerator
heatman101
Dec 24, 2010 | Microwave Ovens
Fridge not working but freezer is ok!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 24, 2010 | Zanussi Microwave Ovens
Microwave Ovens Logo
444 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
