Question about Lexmark X7550 InkJet Printer
Can not get printer to copy 2 sudes of a paper
  • Steve Allison
    Steve Allison May 22, 2011
    Check your owner's manual; most printers won't do the 2nd side without manual intervention.
    My (retired) Canon did the manipulation internally but this is still not common.
  • Official Brand Answer
  • 3,344 Answers
Try to unplug and replug the printer into the power source to reset it. When the printer turns on, try to copy 2-sided again. Refer to the Lexmark 7500 Series User's Guide for the step-by-step instructions on how to copy on both sides of the paper.
Notes:
  • Use only plain paper in Letter or A4-size. Do not make duplex copies on envelopes, card stock, or photo paper.
  • You cannot print duplex through the PictBridge port.
Posted on Jun 01, 2011
How do I copy 2 sided copy from 2 sided original on hp Officejet 4630 e- All-in-One Series
copy one side, then take copy and put back into blank paper try and then copy other side. trial and error will tell you how to put paper in paper tray but usually printed side up, top in
Sep 18, 2015 | HP Office Equipment & Supplies
My zebra tlp 2844 not print multiple copies even if I specify the number of copies in the setting of the printer
Do a hard reset on the printer. Completely remove the printer software/driver and reinstall from a new source (manufacturer website)
Mar 09, 2014 | Zebra TLP 2844 Thermal Label Printer
The orange lights are flashing, is there something wrong?
Try:
1 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
2 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
Oct 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
This morning I thought I would print out some Shamrocks (for T.S. windows) on green paper. I put the green 8 1/2 x 11 in the bottom tray and asked the printer to print 5 copies. It would print 1 copy and a...
Was the green paper the type kids use in school. When my kids were little we called it contruction paper. If this is the case, your printer is smart enough to know that this paper is thicker than normal. It's responding as it should. Next time you want to print on this type of paper - select this in your printer's software control panel.
Feb 26, 2010 | Office Equipment & Supplies
Hp officeget all in one error 0xd05d10c
try to plug out and plug in several times...
check for any paper jams, cartridge jams or low ink...
If all is OK, better to contact nearest service centre.
The problem may be related to logic board.
Jan 11, 2010 | HP OfficeJet 4255 All-In-One InkJet...
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
Make a copy doube sided-2 in one from a driver license
this depends on the printer.
- copy normally
- take the paper that has the copy, put it in the tray and copy.
- if it worked nice luck , if not flip the paper, put it down side up, and on until you get it right.
Mar 26, 2009 | Minolta - DI200F Printer
EP4000 Back to back copying paper jams
THE INK MAY NOT BE TOTAL DRY WHEN MAKING BACK TO BACK COPIES, SOMETIME YOU NEED TO LET THE PAPER TONER DRY, LET THE PAPER COOL OFF BEFORE PUTING IT THREW THE MACHINE AGAIN, AND I KNOW ITS A PAIN IN THE BACK SIDE.
TRY IT
CANDYMANGANDY
Jan 28, 2009 | Minolta EP4000/5000 CS/PRO Copier
Paper crinkles for fax or copies
either your feed rollers are bad or there is a piece of paper stuck
Dec 05, 2007 | HP LaserJet 3030 All-In-One Printer
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Lexmark X7550 InkJet Printer Logo
93 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
