HP CUE Status Root Error - Office Equipment & Supplies
  • 4 more comments
  • franklamar Sep 24, 2008
    HP CUE ROOT ERROR
  • ellimac Nov 20, 2008
    When I boot up my computer, I get a box that says "HP CUE Status Root not working". When I hit cancel, it goes away until I boot up the computer again. It doesn't appear to be affecting anything, it's just really annoying.
  • lmider Nov 21, 2008
    HP cue status root stopped working. Also I get a pop up that tells me that the Solution Center was not completely installed to look for Solution Center disc to finish installing. I do not have or ever had a solution center disc. My printer ballon is not working properly like it used to. It used to tell me when I had ink, not I can't open it from the small icon in bottom right corner or screen.
  • yorkiegirl1 Nov 30, 2008
    I also have the same problem, but it doesn't seem to affect anything at all. I wish someone could send a reply on how to fix though! :)
  • jackieannhen Dec 02, 2008
    Has anybody any idea what this problem is, it doesn't seem to be causing any problems but it's just annoying
  • hturko Dec 03, 2008
    I have an OfficeJet 6310 all in one and I get this messege when I attempt to scan. Does not effect printing. how do I fix it?
It appears to be a problem with HP Cue Device Discovery Service, the tray notification that tells you when your ink is low, etc.  I solved it on a Vista machine by taking Cue out of the Startup tab in msconfig.  (Could show up as HP Cue Device Discovery Service, or  hpqtray08.exe.)  Note that this will also disable the tray icon and its automatic notifications.  All it does is take Cue out of the startup list, but we don't see the error any more and it hasn't affected the printer's functions.
HP has further advice on deeper "cleaning" for the error: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=bpy20854
I haven't come across anything other than manual methods of getting rid of the error.  No updates or patches that I've found.
Posted on Dec 15, 2008
3 Suggested Answers
SOURCE: HP Cue Status Root has
ça m'etonne plus que chez HP ils licencient un max , c est une réponse à la con et le mec y ferait mieux d"aller à la peche que de te repondre des conneries pareilles .
sous Vista.
methode rapides .
1 /Panneau de config
2 / outils administration
3/désactiver le service HPCUE
et voilà tu ne seras plus embeter parce truc de merde .
il doit avoir une autre solution pour virer définitivement ce probleme , on verra plus tard fais dejà ça et ton pc va demarrer normalement et plus vite .
Posted on Oct 24, 2008
  • 86 Answers
SOURCE: hp cue status root has stopped working
click on the start button go to start search bar and type services.msc and hit enter now a window will open look for hp cue in that and check status it should be started and automatic not mannual or automatic delayed if its started then there is a problem with the cue version of the hp software
now try downloading the driver through the link and reinstall the software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3311800&lc=en&cc=us&dlc=en〈=en&cc=us
Posted on Jul 10, 2009
Hp cue status root has stopped working
Jul 10, 2009 | HP Deskjet D1455 InkJet Printer
Error= hp cue status root must close system
hi,you can try restoring your computer to an earlier time,with the system tools located in the start menu.
Mar 04, 2009 | HP Pavilion dv6000z Notebook
"hp cue root status has stopped working" problem
This computer has OS preinstalled and a Recover CD (called RESTORE) supplied by the manufacturer.Insert this (black colored CD) let it ry to boot. Be patient and when prompted remove his CD and follow the instruction as it appears on the screen........sodeep
Mar 02, 2009 | HP Pavilion dv6000z Notebook
Hp CUE Status Root has stopped working ERROR
You should try using Windows Restore. Restore the computer back to when it worked correctly. Then try downloading the latest software for your scanner, etc. from the appropriate websites. i.e. support.hp.com
etc...
That's probably the easiest way to do it.
Feb 20, 2009 | HP Pavilion dv9700t Notebook PC
i had this prob. the "hp cue root " error isnt a hp thing, its a microsoft thing. i beleive it was caused by installing a older model printer AFTER installing a newer model. (i had a hp 2500 series,then installed drivers for a hp 1400 series)
just go to control panel, then "programs and features" , then uninstall everything that is assoiated with the printer your no longer using. just deleating the older printer from the "printers" folder won't do it. (this is assuming that you dont need both printers)
I havent gotten the error message since i did this. besides, its a good rule of thumb to not have drivers that you dont need on your machine anyways.
hope it helps
mkyckrv1
Feb 07, 2009 | HP Pavilion dv6000z Notebook
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
I need hp cue status patch plz
please i have vista and a message hp cue status
Dec 01, 2008 | Office Equipment & Supplies
Continuous error message
delete the hp cue discovery on your add/remove programs
Jul 17, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Cue Status Root has encountered a problem and needs to close.
sous Vista.
methode rapides .
Apr 15, 2008 | Office Equipment & Supplies
4,574 people viewed this question
k24674
jasbo
jasbo
