Question about Yard Machines 24a 452g729 5.5 Hp Chipper Shredder
Balde wheel is engaged while trying to pull start making the task extremely difficult. is there a clutch mechenism that is not dissengaging?
  • 843 Answers
No. The blade is like a flywheel and is connected directly on the motor shaft. However, these usually have separate choke and throttle handles. I have found that they start easiest if the throttle is set pretty low and the choke is closed. Once it starts to fire, then slowly open the choke - allowing it to pick up a bit of speed before you open the choke all of the way. Then wait a few seconds before turning up the throttle. On the other hand, if you have debris in the machine making it hard to turn, you will have to clean some of it out before you start it. Good luck, Al K
Posted on May 22, 2011
Clutch not engaging
Well, it would shift easily with engine off, because the transmission input shaft is not turning. Engine running and clutch engaging good, the input shaft would again be stationary and allow smooth shifting.
What you have to determine is if the clutch disc or pressure plate is bad (a new clutch is needed), or if the pedal hydraulic system has a malfunction. When you push the pedal down, a rod from the top of pedal pushes into the clutch master cylinder bolted to the firewall under the hood. This cylinder has a reservoir filled with brake fluid. When the rod forces fluid from the clutch master down a steel line and into the clutch slave cylinder down on the transmission bell housing, the hydraulic pressure forces a plunger from the slave cylinder to extend and push the clutch fork lever a small amount, enough to force the clutch release bearing (aka throw-out bearing) against the pressure plate. This relieves pressure on the clutch disc and input shaft becomes stationary for easy shifting.
Jul 26, 2013 | 2000 Chevrolet Blazer
How do I adjust the clutch? Clutch engages when
A high clutch pedal is good.
There should only be about a half inch of pedal freeplay, before you start to feel resistance.
So the clutch should not engage until it is almost fully released, near the top.
The makes shifting the easiest.
If the shifting is difficult when cold, then put the transmission in neutral and let the clutch out when you warm up the engine.
That will warm up the transmission oil.
Of course you could also check the transmission oil level and change it.
But your question makes me believe you may need more experience on a stick shift. Make sure you do the H pattern carefully, and do not get lazy and turn it into an X pattern.
May 28, 2010 | 2003 Ford Focus
2001 YZF 600 R thunder cat: Yamaha yzf 600 Thundercat when under heavy load or...
Many YZF 600's have a problem with second or third gear, under heavy accelleration they will jump in and out of gear, the fix is in the gear selectors,an internal box problem.
If it is a clutch problem, ride in top gear at 100kl\hr and give the clutch lever a flick, see if it grabs or slips for a while and then takes up.
May 05, 2010 | 2001 Yamaha YZF 600 R thunder cat
Runs until clutch is disengaged
I would have to say it is some security setting. Most likly it is your seat, if it should turn off when you stand up this is most likly it. So you want to make sure the wires are plugged in better that come out from the bottom of the seat. make sure the connecters are clean when you reatatch them.
Apr 21, 2010 | Craftsman Woodstock Percussion Crcbm ...
I have a cub cadet 2130 mower. After 5 years, when I pull the switch for the baldes to engage , nothing happens. The problem first styarted by my pulling the button and in about 10 seconds the electric...
the swith contacts are probaly bad or there is a lose wire on it if you know how to get it out check for lose wires and try going to an electric supply store and ask for electrical cleaner that will not harm plastic and spray it in any openings in the switch if you can not get it out take it to a repair shop.
Sep 24, 2009 | Oregon Scientific Electric PTO Clutch for...
Difficult to start chipper while gears engaged
The drive belt may be the wrong size if there is no play in the clutch. I have a 10 hp, but there is a common manual for the 10 and 8. My belt is a 4L380.
Jul 12, 2009 | Troy-Bilt Chipper Shredder
Stuck parking brake
take rear wheels off and find the cable and bang it free or get under the car and look for the cable and try to pull it free if you get it off dont use it again!
Jun 30, 2009 | 2000 Dodge Caravan
Pto willl not engage
Hi mate, Although my trade is repairing turfcare machinery, I have no experience with this model, so I will try my best. Firstly, the clicking you hear will probably be the electric clutch engaging/dissengaging. Firstly, see if you can get the clicking with engine off, keyswitch in first position/on/lights on dash. You may have to place something heavy on the seat and have traction pedal in neutral. MAKE SURE YOU DO NOT ENGAGE THE STARTER MOTOR/START THE ENGINE THROUGHT THIS!
Now have a look under the footwell on top of the deck and try to determine where the clicking is coming from, there will be a clutch there somewhere joining the engine drive pulley to a deck pulley, Also at this point check that both belts are on and with the ENGINE OFF! spin the blade/blades with your hand and ensure that the deck belts are not slipping on the deck pulleys. If they are you will need to establish where the tensioning system is. (Sorry i know pretty vague)
Back to the Clutch, once you establish where it is, engage the blades ENGINE OFF! and you should feel a greater resistance turning the blades as you are now turning the engine as well, beware though, it is theoretically possible to start the engine by doing this, but you will almost certainly not be able to spin the blades that quickly by hand.
If it is clicking to engage but not turning the engine pulley when spinning the blades by hand, then try tapping the clutch lightly as it may not be fully dissengaging.
I would put money on it being either one of the belts coming off/snapping, the blades jamming or the clutch not engaging fully.
If you find that the clicking is not the clutch engaging and its actually getting no power to the clutch then you need to go back to the pto switch and go through all safety switches! (good luck, it usually ends up with me bypassing them or running a new cable to the switch,then, smoke, shouting, swearing etc etc!) Either not advisable.
In doing all this you should have been able to have determined the problem be it one that I have mentioned or another.
Hope this helps,
Chris.
May 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Clutch wont dissengage
1) Can you push the bike while it's in gear with the clutch pulled in? [If so, clutch is disengaging OK]
2) If not, check when you pull in the clutch lever that it pulls all the way through to the actual clutch [If not, replace broken clutch cable]
3) If so, clutch is binding. Either fix it properly by stripping the clutch.. or just brute-force the plates apart. :-)
Brute-force clutch plate separation: First make sure you have enough oil in the engine (wet clutch), then basically you're looking at either riding it with the clutch lever pulled in until the plates come apart or with the rear wheel in the air CAREFULLY running it in first gear against the rear brake while the clutch is pulled in.
Mar 20, 2009 | 2003 Suzuki RM 125
Arien524 when clutch is engaged the wheels donot pull right away
Sorry I should have posted this as a solution.
You might want to check the friction wheel to see if it is either worn down and needs adjusting or if it needs replacing.It could very well be just an adjusting. The friction wheel is located inside the panel under the engine. When looking inside the panel and you pull on the handle to engage the wheels you will see the round disc pull towards the friction wheel if it doesn't pull in tight enough you will have problems.Also check the belt and the idler pulley for the drive make sure the idler pulley moves easy and that it puts enough tension on the belt.
Dec 13, 2008 | Ariens 34 In. Zoom Series Riding Mower
Yard Machines 24a 452g729 5.5 Hp Chipper Shredder Logo
209 people viewed this question
Top Yard Machines Heavy Machinery Experts
Roland W VanLue
Roland W VanLue
rjivaro
donald boissonneault
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
