Question about Garden
Need to replace broken pull rope - Garden
    President:
  • 3,074 Answers
You will need to remove the four bolt on the shroud, and the one on the oil stick. Once the bolts are removed tip shroud upside down and wind clockwise/counterclockwise which ever put tension on the pulley, then wind it six or seven times, line the two holes up, the one the cord goes through the outside and the one on the plastic piece inside the shroud, pull the cord through, let go and it will wind, tie a knot on the one on the inside of the shroud and singe the end of the knot. Pull on the cord a few times to make sure it going to hold, put shroud and oil stick back on, thread cord through handle. Hope this helped Tim
Posted on May 22, 2011
When you pull the Rope the flywheel doesn't turn
sounds like the teeth in there have fell out or broken off. take it back off and be sure when you pull the rope the teeth come out.
Sep 13, 2016 | Garden
How do I replace the starter (pull) rope on a toro ccr2450 (model 38413)?
Although it looks like you simply un-bolt the recoil starter you need remove the whole blower (flywheel) housing as there are nuts on the back side.
  • Once the housing is off, remove the broken rope and prepare a length of rope to replace it base upon the old ropes length. Probably close to 6 feet.Don't forget to put the pull handle on the new rope.
  • Tighten the recoil pulley in the direction it normally turns as you pull the rope out until it stops.
  • Slowly back of up to one turn to align the hole in the pulley with the housing hole and hold it in that position while you insert the rope and try a sturdy knot.
  • Slowly let recoil assembly pull the rope back in and test that it is working properly before re-installing the housing.
  • Once you are satisfied that the recoil is working properly re-install the remaining covers.
Jan 15, 2015 | Toro Garden
HOW TO FIX BROKEN STARTER PULL ROPE ON TB65SS WEED EATER?
You need to remove/disassemble the recoil starter assembly to replace the rope. Be carefull the spring does not get away from you if you do take iot apart.
Sep 21, 2014 | Garden
How to replace starter rope in lawn mower
First assemble the following: Pliers, large vice grips, 'c' clamp or a bench mounted vise and new rope. Remove therecoil housing from top of engine. Turn it over, find the end of the broken rope and on pull it until it is fully extended but do not remove yet. While holding the rope extended place clamp device on the rope housing clamping the spool and housing. Be careful not to put too much pressure on the housing, just enough to hold the two pieces. Carefully remove old rope and thread the new rope through the small hole in the housing and into the slot in the pulley. Tie that end of rope into a knot to prevent rope from coming out. While holding other end of rope, carefully remove the clamp from the housing and slowly let the rope rewind into the housing. Replace rope housing onto top of motor. HOW TO Replace Broken Lawnmower Pull Cord
Sep 01, 2014 | Garden
Troy-bilt pull rope torx screw: Is there a trick to remove the torx screw in the center of the starter spring housing?
There is no trick, you would just use a torx screw driver. If your spring isn't broken don't do this. If your rope is broken you can fix easily. Replace old rope with new rope of equal size, place rope into spring wheel and turn counter clock wise holding the spring wheel. place other end of rope thru hole in shroud, remember to hold tight you have a lot of tension there. Pull rope thru enough to tie a knot, replace your pull handle , untie the knot and you should be fine. GOOD LUCK.
Aug 12, 2011 | Troy Garden
Pull rope wont retracxt all the way
coil spring inside needs to be recoiled or tab is broken or off the hook
pull the rope assembly off and inspect/ repair or replace
Jul 24, 2010 | Karcher 2500 PSI Pressure Washer
The starting cord has broken and I need to make repairs . I would like some guidence
Take the housing off for the pull rope. Inside you'll find a spool. Take that off and underneath you'll find a spring. Replace the pull rope and connect it to the spool like the old one is. With the handle outside of the case run the rope through the pull rope hole then attach it to the spool. Wind all but a foot or so of the new rope back onto the spool. The spring will have a way of attaching to the case and to the spool. Attach the springs to the case. There will be a notch cut into one side of the spool. You need to lay the rope into this notch and then place spool back into the case at the same time attaching the spring to the spool. Don't worry about tensioning the springs. Once the spool is back in you need to start winding up the spool in the direction that tightens the spring. You'll need to make about 5-8 rotations depending on the length of the rope. At this point, position the notch in the spool even with the hole where the pull rope enters the case. Pull on the pull rope handle until you pull the slack rope back through the notch and outside the housing. Then release the rope and the slack should be pulled back inside the housing and wrapped around the spool. Here is a video on changing a pull rope on a lawn mower. The idea is basically the same.
http://www.youtube.com/watch?v=i3ZMVFi0yqY
Nov 27, 2009 | Ryobi Garden
Starter rope pulley will not pull the rope back into the leaf blower.
Most commonly, the recoil rope rewind spring is broken. However, inspect the recoil housing assembly first to make sure no debris or rope fragments have prevented the rope rotor from rewinding. Always remove the spring 'AS A LAST RESORT'. Many rewind problems can be solved by inspection of the rotor and not have to remove the spring. In case you do, I will include instructions on how to re-install.
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Nov 21, 2009 | Craftsman Garden
Broken pull starter rope
remove pulley that rope goes on, wind it with new rope, wrap it till it is full, then feed rope thru hole in housing, put pulley back in place, put rope thru pull handle, pull thru till you feel spring catch tie a knot and that should do it......be careful when removing pulley not to dislodge recoil spring
Oct 22, 2009 | Garden
Pull rope does not return
Unless the rope has broken, you dont need to replace it. The problem is probably the rewind spring. It is located under the starter pulley (the one the rope is in). The best thing to do is pull the unit apart and see if you can see if maybe there is something holding the rope up. The spring is a little dangerous to replace. If you go for it, be careful....Lee
Sep 03, 2009 | Garden
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
