Question about Dell Inspiron 1100 Notebook
Dell Latitiude 1100 Will not boot has poweron issue
I have a Dell L 1100 that will not power on.Power supply is good and battery condition is unknown.Here is the weird part if I tap the area around the start button an amber light flickers on briefly.If I thump the bottom sides of the palm rest 2 green lights flicker on. In both cases there is no attempt to boot. Do I have a haunted laptop or is this a known issue?
Email help is welcome and appreciated !!
  • biged143 Aug 18, 2008
    seems to be a common problem with the 1100. Mousepad which has a magnetic reed switch keeps it from starting.Found the solution on a different forum.Thanks for trying.
    Champion:
  • 221 Answers
I also have a dell inspiron 1100. It seems that it has overheated, and your motherboard or CPU has fried, or died from the heat. What you say sounds like a motherboard failure
There is currently an ongoing lawsuit. Also, take my advice, and instead of trying to fix it, you're better of getting a new computer, as the dell is getting old anways. I spent some extra cash and got myself a vaio.
Posted on Aug 15, 2008
My dell inspiron M5030 turns on showing the dell logo and then it turns off
I would remove the power supply, battery, hard drive and RAM. Power up the laptop with just the power adapter and enter bios. If it goes to bios OK, select the default setting. Press F10 and let it try to re boot.
Remove the power supply and fit the RAM. Insert the power supply and try to boot. You should have error message on screen. Remove the power and insert the hard drive. Connect the power supply and attempt to boot.
That sequence should show the issue at the point that there is no display that is where the issue is.
Dec 13, 2013 | Dell Computers & Internet
When turn shows logo turns off
That sequence should show the issue at the point that there is no display that is where the issue is,
Dec 13, 2013 | Dell Inspiron Computers & Internet
Orange light comes on only when i press the power button
Lots of things that can be. It is 1 of the many parts failed to allow boot. Its usually a failed hard drive or power supply. More often its the power supply due to the low wattage dell specific units they were at that time.
Apr 16, 2010 | Dell Dimension 1100 PC Desktop
Dell latitude d500 wont charge.
If the original batteryand the system works on AC power, then replace the battery.
If the battery has been replaced, then it could be a motherboard charger failure
Jan 25, 2010 | Dell Latitude D500 Notebook
Power or motherbaord failure
open it ...remove the bios battery and after that put it back ..this will reset it ...and will boot ...just set the time and date and press f10 to exit and save ...
if it still fail to boot after that it has another issue ..probably a cpu fan or a ram memory
Jan 18, 2010 | Dell OptiPlex GX280 PC Desktop
Dimension 1100 not booting. In Boot sequence screen, says "Hard drive not installed"
Your hard drive is probably toast and needs to be replaced and Windows reloaded.
Make sure to check your BIOS settings first and make sure the drive is showing up in there and it's not deactivated.
Sep 10, 2009 | Dell Dimension 1100 power supply ** FREE...
Dell Inspiron 1100 Monitor
HI, Follow these below steps
TAKE OUT BATTERY, REMOVE MAINS SUPPLY, HOLD POWER BUTTON DOWN FOR 30 SECS PUT POWER SUPPLY IN ONLY DO NOT PUT IN BATTERY TURN ON LAPTOP NOW PUT IN BATTERY
Jan 11, 2009 | Dell Inspiron 1100 Notebook
Dell latitude 100L will not start
Couldnt tell you if its going to solve your problem but you can get a cheaper replacement rechargeable battery here - Dell 100l battery, also good for the inspriron 1100 and 5100 range
Dec 24, 2008 | Dell Latitude 100L Notebook
Won't boot up and battery and power lights flickering fast...
when you start it , do you have it running on the power supply or battery? Or, does it not matter?
Nov 04, 2007 | Dell Inspiron 1100 Notebook
Dell inspiron 1100 booting problem
Motherboard or power supply is toast. A factory authorized repair center should look at it. Good lUck
Sep 09, 2007 | NEC Versa (808-895500-001A) Drive Case
Dell Inspiron 1100 Notebook Logo
128 people viewed this question
Alun Cox
