Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
SONY KV SW 212 M80 Screen sowing pin cushion distortion. Screen is squeezed on the side and the side is curved inward.
    Top Expert:
  • Sony Master
  • 74,198 Answers
Hello
Its pin cushion distortion circut had some trouble with it. There is an Ic and one transistor wich controls the pincushion effect. In most cased the trasistor that fitted on a heat sink, will have loose soldering at its terminals. this transistor will heat up during working, and repeated heating an cooling will make solder terminal loose contacted and it is normal fault. locate this transistor, very near to the LOT, resolder its solder terminals by applying a little more solder. It is best to resolder most of the surrounding solder terminals of high watt resistors, without making any solder bridge in between the solder points. If these does not helps you, replace both the IC [an eight solder terminal one, small IC] and the pin out transsistor described earlier at the same time. this will solve your TVs problem. OK.
Posted on May 22, 2011
My KV-SZ29M50 SONY WEGA TRINITRON FLAT SCREEN DOES NOT OPEN WIDE SIDE IMAGE BUT ONLY IN MIDDLE & IT HAS OUTSIDE CURVED SCREEN.WHAT IS THE PROBLEM WITH IT?
Pin cushion distortion. It is a fault with its circuit board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 27, 2016 | Sony Televison & Video
PICTURE CONCAVE OR CURVING ON THE SIDE
Pin-cushion distortion. Contact any service technician. Its convergence part circuit need a through check-up. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 10, 2015 | Televison & Video
Lg flatron 29fx4ble
Sounds like pin-cushion circuit have failed. Contact any technician.
May 20, 2013 | LG Televison & Video
Picture is too large to show on screen
Check its "Pin-cushion" section circuit for the fault. An IC is used there to control the pin cushion distortion. If this IC has got faulty, this type of fault can occur. This is actually a skilled work. If you are not ahndy, seek any technicians' support.
Jun 18, 2012 | Sony KV-36XBR400 36" TV
I have a tedelex ec29187 with a funny picture. The sides seem to be bend inwards. A guy said they call it a east west problem. Help me with a solution please.
Ity is an East West porblem [Pin-cushion distortion] itself. You ahve to check its pin cushhion circuit to detect faulty component/s.
Apr 12, 2012 | Televison & Video
Vertical pinch on left hand side of crt
You mean the picture on the left side is curved out? Or is it restricted to the very top and very bottom?
If you have the curve problem, look in the menu and see if there is a pincushion control and a pin cushion balance. Adjust the balance until both sides curve the same, then adjust the pin cushion control to remove the curve.
If you are only having the problem in the corners, look in the menu for a corner correction control and play around with it to see if it corrects your problem. If the monitor has no OSD (on-screen-display), then it may be too old to have these controls. You may have to open the unit and see if there are any physical adjustments (little potientiometers). You might want to leave this to someone who knows what they are doing since the high voltage circuit can have 25-35 kV. Considering the price of CRT monitors, you might be able to find a new one for under $50.
Jan 22, 2009 | NEC MultiSync XV17 17" CRT Monitor
Sony Picture Squeezes In On The Sides
Your TV has dry solder joints in "Pin Cushion" area, Its part of Horizontal deflection stage in TV and it requires resold work.
A tech person will understand above technical advise easily.
Need further info, let me know please.
Sep 30, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Loewe TV with pin cushion distortion
Yes if you could give me a model #, it is probably a diode shorted in pincushion area, or a capacitor.
Oct 05, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
397 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
