Question about Vacuums
DC15 brush bar first intermittent, now won't run at all at any angle. Purchased Torx 15, removed 2 plastic covers on right (looking from the front) side. Blue/yellow wire seemed stuck where it entered the black rubber grommet. Tried giving it a gentle tug . . . nothing. Firm tug pulled out 2 stripped ends. So I'm hoping that replacing those wires is the way to go, per several suggestions here. Problem is how to thread new wires in. Teachmhs provided advice about using an ice pick . . . Before I do that some additional detail, with pictures, would sure help.
4 Suggested Answers
  • 40 Answers
SOURCE: My dyson DC15 the brush cuts in and out.
http://www.espares.co.uk/datastore/ProductManuals/350256.pdf
Check the above link to see if it helps. It shows you how to break down the DC15 to check for issues. Also try inspecting the circuit board for loose wires. There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board. And I really believe that in your instance, the problem is a loose wire between the circuit board and the brush motor.
You can try calling their helpline at 866-MyDyson for further help
Posted on Sep 28, 2010
  • 456 Answers
SOURCE: The wires feeding the brush bar assembly to my
hi.
if the spade connectors are the same size then i would connect white to yellow and then blue to black
Posted on Apr 03, 2011
  • 694 Answers
SOURCE: I am trying to disassemble
There's a tab at the back of the rail that needs to be released. Turn the vacuum on it's side, slip the tip of a standard screwdrive into the space between the rail and the back of the vacuum, and tap lightly with a hammer. Tap toward the front of the vacuum a few times until the rail is far enough forward to be slid out fairly easily. As a side note, the rubber covers do not need to be removed to do this.
Posted on Jun 19, 2011
I have a Dyson DC 15 Vac. The brush does not spin consistently while using. It goes on and off during use. I have checked for loose wires, etc. Have found nothing. Any suggestions?
This can happen if two tiny wires that are connected to the circuit board and lead to the beater bar are broken. These wires brake where they go through a black rubber grommet. You need a torx screwdriver (No: 15) to remove two plastic covers to access these wires . When looking from the front of the vacuum, the circuit board is located under the gray covers on the right side of the vacuum. There is one big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
See photos at here.
Jul 12, 2011 | Dyson DC15 All Floors - The Ball Bagless...
Beater bar not working on newer ball pet unit
HighnTools posted this solution some time ago. I think it can help you solve your issue.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
Aug 29, 2010 | Dyson DC15 All Floors - The Ball Bagless...
DC15 Vac comes on but the head will nmot come on. Local Vac shop said circuit board was burn up,can I repair myself. where do I get parts
HighnTools had posted this solution - try it.
I hope this solves your problem.
Aug 16, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
When I press the botton next to power button in order to activate the bruch for carpet cleaning. The brush does not spin anymore.
HighnTools posted this solution a while ago. This might be related to your problem: I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
May 21, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Brush does not spin all the time
The above was from HighnTools.
May 11, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Bought clearance item Sunday just found out the brush bar was motorized it turms only when i move the vacum back and fourth it should turn on its own right ? I have very little suction from the bottom the...
This appears to be a loose connection. The below post was answered by highntools a while ago. It probably is related to you problem. That is why moving it back and forth makes it go on.
Mar 09, 2010 | Dyson DC15 All Floors - The Ball Bagless...
When I vacuum the carpet it won't engage into the brush mode, or it does intermittenly. It stays in the brushless mode for the most part
Aug 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beater brushes don't work, what to do? They only work when the canister is in about an 85 degree up position.
Jul 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Dc15 dyson when in the upright positon it woun't turn on
This was originally posted by "highntools" and I believe is related to your problem as well.
Check out this link also: http://www.espares.co.uk/datastore/ProductManuals/350256.pdf
And lastly, you can try calling their helpline at 866-MyDyson for further help
Dec 21, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Beater bar on Dyson upright won't turn when handle is lowered
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Vacuums Logo
59 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
