Regards,
Tony
What leads you to believe it is the iron that is faulty and not the fuse or breaker of the wall outlet? I need the model number. Manuals are not ready available on the net so Shark is the on place to get them and per their site http://www.sharkclean.com/cgi-bin/livew/... when you click on manuals it says I need the model number.
Sometimes these irons are not as serviceable as on might think. Often the are epoxied in so that the average Joe cannot get into it without cracking the base, forcing them to send it to their factory for a fix.
I see you have another tech helping you now. It's one of the downfalls of this site. If I go to bed and the customer waits a while to respond back then 4 hours goes by while I'm in bed. A process I have no control over. How far up the cord do you manipulate the cord? Are you messing with it by the base? Or a little bit up the cord itself? If you were messing with it a bit up the cord you could put a simple splice adapter on the cord a bit down from the suspected break and add a new cored from there.
Once you removed them screws now just take and gently pry the back end out a bit and the cover comes off from the back and you lift it forward exposing the inside of the Iron. People come on here all the time thinking they know whats wrong with there item yet seeking information. I am only being thorough. There is no need to yell.
Good day!
Double check again all screws and remove it.
If no screws found.please look for the possible lock inside.
thank you
I need to remove the cord base because there is a short in the cord and it does not keep the power on. Sorry I didn't include this information in the earlier post. Putting an extension cord on will not fix the problem. I need to get into the cord assembly and rewire the iron.
I know it is the cord because when you manipulate the cord, after it has power itself off, the power will come back on if the cord is in a certain position. The model number of this SHARK RETRACTABLE iron isG1477R.
I believe the problem is deep within the retractor assembly. When the cord is fully extended you can power the iron on if you also wiggle the wire with tension. The more this is done, the quicker the iron powers off which leads me to believe the problem is where the cord is attached to the retractor mechanism. So again, the question is. How do you take the cord assembly off the base of the iron in order to work on the wires where they connect internally!
