Got sitecom wl300 wireless extender.. im trying to set it up but for some reason i can't just get to its setup page 192.168.0.234 .
2 Suggested Answers
SOURCE: can't log on 192.168.0.234 i have belkin router
First reset your router to factory defaults.
You can reset it with RESET button press it for 10 secondsd it is in back side of router.
Then connect your router to comuter with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
for belkin router
http://192.168.15.1
user name as "admin" and if it want password then "admin" or blank or "password"
Then you can access it's configuration.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 02, 2009
I got a problem in connecting my samsung galaxy GT-7500 to sitecom extender 300N .. I have tried to change the IP address but it doesn't work with me . Any help plz?
Which modes are you trying to use this Sitecom? If you have the Sitecom as your Access Point (AP Mode), then you would need a LAN connection to your internet gateway (DSL, Cable Modem, etc). I didn't see any LAN hook up so I assume you are trying to use it as a wireless repeater. So you need to configure the unit differently. The 3rd mode is called Bridge mode. Again, you need to have a LAN hook up to your local network with a router or network switch.
Because your Tablet is connecting to the Sitecom okay, which mean that you either have the Sitecom setting for AP mode or Bridge mode. And the reason it didn't give you access to internet because there is no internet gateway connection to the Sitecom (LAN). I hope this answer your question (or confuse you totally).
Feb 15, 2013 | Computers & Internet
I cannot switch off the DHCP in the WL330 sitecom
You can find the user manual here: http://www.sitecom.com/wireless-range-extender-300n/p/714. I don't know your specific software, but on mine you have to click on every page to save changes. If you make all changes then save it will not save all changes.
Nov 28, 2012 | Belkin Computers & Internet
Not able to connect the extender to my apple time capsule? no wps button. can i use this extender?
Hi, yes you will be able to use the Netgear range extender with the Apple Time Capsule, provided you configure the Time Capsule's wireless settings based from the wireless security you have setup on the Netgear router or extender. No need for WPS button. Just treat the time capsule just like another wireless laptop.
For instructions in setting up wireless settings of Time Capsule click on this link -->> http://www.apple.com/timecapsule/wireless.html
Hope this helps. Glad to be of service.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
Can't log on 192.168.0.234 i have belkin router
http://192.168.1.1
or
http://192.168.0.1
for belkin router
http://192.168.15.1
Thanks.
Sep 02, 2009 | Belkin (F5D7230-4) Router (587009)
Can't setup to virgin braodband
You mean ascii and hexadecimal.
  • Hard wire your router to your PC with an ethernet cable
  • Open your web browser, go to website http://192.168.0.1
  • Input username/password both are "admin" (without the quotes)
  • choose "wireless settings" (third tab from left)
  • go to "security" (fourth tab from left)
  • Choose WEP (if the first box on this page already says WEP you may skip this step)
  • choose 64-bit
  • type random 10 digit code into key 1 (eg. 38-38-2D-E3-B0)
  • Save settings (bottom of page)
  • write code down somewhere or make it easy to remember
  • disconnect your ethernet cable from router, try to connect to wireless network, enter code (from above) and it will connect.
Jun 26, 2009 | Sitecom (WL -004) Wireless Adapter
Problems configuring WL-130 Wireless Extender
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Nov 12, 2008 | Computers & Internet
Wireless extender
OK.
It's pretty easy:
1) turn on both devices
2) connect to sitecom device.
- you may have to manually set your IP address. (from network resources control panel, TCP/IP tab. Check the istructions, cause you have to choose an address in the same subnet of the sitecom range extender. I mean, the first three numbers must be the same, and the last number of the address must be different, between 3 and 255).
- now you can type the sitecom address into the address bar of your browser (allow pop ups from that address!). The defaut user name is admin, as well the default password.
3) Ok, now you're connected and you just have to set this way in the basic settings:
working mode: universal repeater
now click on site survey and remember the ssid of your main network, and the channel number.
channel: type the channel number of your network (IT MAY CHANGE WHEN YOU TURN OFF\ON THE ROUTER!! so you'll have to change it maybe every day..... **** sitecom device, I HATE IT)
ssid: the ssid of your main network.
4) click apply.
Of course if your WLAN is protected you must set the rigth password and encription algorithm...
Now it should work.. but remember, everyday you will have to change the channel, and sometimes ou will have to reset it, from he toolbo tab.
IT,S BETTER NOT TO BUY THIS DEVICE, cause even the latest firmware is not working properly.
Jul 13, 2008 | Computers & Internet
Problem with sitecom wl-130 connection
I think I have the solution: you have to click on the basic settings tab, then n "site survey" button, then (optional) on "refresh" button.
Now you will get the information about your network, and you just have to check the channel number of the signal from your main router. then you have to set that channel in the "channel" button of the basic settings tab. You also have to choose Universal repeater as working mode of the sitecom device, instead of Access Point.
Hope it helps.
By the way, all these settings should be automatic in such a device.... But this sitecom range extender is ****.
I suggest everybody is reading: DON,T BUY THIS ITEM!!!! Spend 10 bucks more and get a working one!!!
Jun 01, 2008 | Computers & Internet
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
