Question about Canon imageRUNNER 210S Copier
We have a imagerunner 210s. we just replaced the fuser unit and now when you try to copy, it copies the original but when it feeds through the exit door, it jams and when you open the door, the paper is folded like an accordian. we are able to manually feed a piece of paper throught the rollers, but it will not automatically feed out the copies. The machine jams every time.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Canon Expert
  • 306 Answers
Please to see the claws. they are 5 claws which pluged on exit unit.
if you open the cover exit you will see them.
the shape like as a tigers claw. but more like as triangle.
they are move by spring, you try to moving. what are they work well?
problem usually cause
- the spring was loose or (you can plug or replace the spring)
- the claws have broken or (you replace a new)
- the claws dirty by crust toner. (you can clean up by your finger or your claw)
good luck.
Posted on May 23, 2011
Paper jam signal
I know your copier has sensor
1. Paper feed sensor in cassette
2.Paper feed by pass tray sensor
3.Transfer unit sensor
4.exit sensor in fuser unit
5 Paper exit sensor duplex unit
may be any sensor displace or broken
its open
please check it and fix problem
Jul 14, 2012 | Canon imageRUNNER 210S Copier
I have a code error e007 01
A E007-01 means that the fuser film is out of home position.... Odds are you will need to replace the fuser unit or the fuser film.... The film is hard to replace... It is a lot easier to replace the fuser unit.. Good Luck
Oct 07, 2011 | Canon imageRUNNER 210S Copier
The copies are very light. I have tried to adjust exposure, no change. I have already added toner. drum? fuser? Clean...what?
firstly clean the beneath the copyglass and clean the optics ( mirrors ), then try...
also try to darker the copy and see what happens, if its still light try to change the drum....
PS are you using the original Canon toner?
Nov 09, 2010 | Canon imageRUNNER 210S Copier
Enter copies into the feeder (Canon 210S). It
This is one of the worest designed feeder from Canon. Have you had the feeder rebuilt recently? If not that will improve it greatly. I would also, go into the user settings and turn the fax exit to recurite late doc. As I said, it is a bear to take this feeder apart if you have not done it before... Good Luck
Mar 05, 2010 | Canon imageRUNNER 210S Copier
Image runner 210s error code E000. What to do?
Your problem in the fuser unit.Check and clean the fuser unit component parts:thermistors,thermofuses,verify the continuity of the heater lamp,and verify the upper and lower fuser roller mechanical.
Nov 24, 2009 | Canon imageRUNNER 210S Copier
GRAY STRIPES ON COPIES
clean the glass. it must have streaks
May 28, 2009 | Canon imageRUNNER 210S Copier
GRAY STRIPES ON COPIES FROM CANON IMAGERUNNER 210S
Have you replaced the drum unit resently? When you had the drum unit out did you see the lines on the drum it self? If so, you need a new drum... If you did not see lines on it the problem may be coming from the fixing film, most of the time if the film is bad you can rub the toner off the page... Good Luck...
Printing on Imagerunner 210s
depends on which additional function you are trying to do.
You have it as a copier only right now, you can add
duplexer for two sided copies
network for your computer to fax and print and scan
document feeder to put copies on top and feed automatically
There are a lot of options you need to decide which function you are willing to pay for.
Good luck
Dec 04, 2007 | Canon imageRUNNER 210S Copier
Canon imageRUNNER 210S Copier Logo
old marine
old marine
