Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Will crank but won't start. I'm not getting a spark to the plugs
    Guru:
  • 666 Answers
First pull the spark plugs out and see if they are wet. If they are dry you may as well need to take your carburetor(s) apart and spray cleaner through all the passageways. As gas sits it tends to turn into a shellac which stops stuff up. There are some stabilizer stuff in a bottle purchased at parts stores and Walmart that you dump in at the end of the year to prevent this type of problem. It is handy in RVs, mowers, blowers, etc anything powered which sits idle for a long period of time.
Thank you for visiting FixYa! have a good one.
Posted on May 22, 2011
305 motor won't start it will crank but can't get
Is the the same engine that you replaced the plugs and wires on ?
Are the plugs getting spark ?
Jun 08, 2013 | Cars & Trucks
Where are the components located on a 1994 E320 Mercedes Sedan?
don\'t understand: cranks fast enough (battery low??) or crank at all??. Need more detail(s);if it cranks at all but slow,you won\'t get a spark;don\'t touch the end of the spark plug wire \'cause it\'d make your butt pucker if/when you get spark!!! honestly.
Jan 29, 2013 | 1994 Mercedes-Benz E-Class
Car won't start 2003 Dodge Stratus sxt coupe cranks but won't start what could b the problem? I tried spraying starting fluid in the air system but it still won't start!
i would check and see if spark pluges are firing. you can take one out and plug into spark plug wire then let the bottom of the plug sit on engine and get someone to try to start while you look at the plug to see if there is any fire. if you have no fire or fuel it would be the crankshaft sencer. it could be the timing belt but the motor would sound different turning over then it used to.
Dec 22, 2012 | Cars & Trucks
Won't start after sitting yesterday and lastnight in cold
remove a spark plug and reconnect its cable, sit it on engine and crank. do you see a spark on the plug?
Dec 20, 2012 | 2004 Ford Explorer Sport Trac
Mac 3516 chainsaw won't start
Electronic ignition units work off speed of rotation so make sure yoy are cranking the engine fast enough, make sure the plug is well earthed against the cylinder whilst cranking, make sure the switch is in the on position, if there is still no spark you will have to replace the unit.
Aug 02, 2012 | Garden
Having trouble getting my new z445 to start when it is cold. It will turn over but not crank. I can give it a little puff of starting fluid and it will crank right up.
It sounds like you aren't getting a hot enough spark. Have you pulled out the spark plug and checked it?
First try to turn over the engine a few times.
Then immediately unplug the wire, use a socket to remove the plug, and check the end of the plug to see if its wet. If it is wet you are getting fuel, if it looks bone dry you aren't getting fuel and I can make some other recommendations.
Plug the wire back in and place the outside metal of the plug against the engine. When you try to crank the engine you will either see a nice spark or you won't.
Let me know what happens.
Jun 07, 2011 | Garden
2001 ford taurus with the 3.0 after sitting a few hours when i go to start will crank and crank and crank for what seems like ever, will start easily after that but when i go to start it for the first time...
Its not the oil, increasing temperature will thin out the oil. If it cranks easily but won't start it could be the spark plugs or the spark plug wires. When they heat up, especially if they are old, they won't perform well. Pull off one of the wires and hold it close to the plug, try to crank the engine and look for a spark. If it sparks them try removing a plug and check to see if it looks wet. If its bone dry it might not be getting fuel.
Jun 07, 2011 | 2001 Ford Taurus
My 2000 Dodge Grand Caravan will crank but won't start.
Hi, if an engine cranks but refuses to start, it lacks ignition, fuel or compression. When the engine cranks normally but won't start, you need to check ignition, fuel and compression. Ignition is easy enough to check with a spark tester or by positioning a plug wire near a good ground. No spark? The most likely causes would be a failed ignition module, distributor pickup or crankshaft position (CKP) sensor.
Jun 06, 2011 | 2000 Dodge Caravan
Truck wont crank. we have put new distributor cap, rotor button, coil pack, plugs, wires, and fuel pump. we also checked our firing order.
you said you repl dist cap that means you don't have a crank sensor you have electronic ing module. remove your elec ing module have it tested most auto parts stores could test your module, or check your coil at the neg terminal. should have power. if not you lost your primary volt from your batt.your secondary power is coming from your electronic ing module from the module to the pos terminal on the coil, when the eng cranks,from the coil to the dist cap , from the dist cap center to the rotor then out to the plugs,this all happen pervided the timing belt or timing chain is ok. the cumbustion chainber needs 3 things , thats fuel, air, and spark.
Apr 17, 2011 | 1996 Chevrolet K1500
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
53 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
