Question about Kenmore Front Load Washer
Model # 417.44042400 When in wash cycle, the machine groans loudly when rotating clockwise (as viewed from the front). There is no abnormal noise when rotating counter-clockwise. In spin cycle, there is an extremely loud banging sound and the machine shakes some. I have verified the machine is level, though the floor in the laundry room is not. We've had the machine for ~6-7 years and this is a new and sudden issue.
  • junkymcjunky May 29, 2011
    I removed the back from the machine and found one of the five arms of the pulley was broken and the belt was slowly moving off the edge.
    I plan to replace the pulley and belt to see if that resolves the issue. Any suggestions as to other parts to replace while back there or anything else to check out as well?
  • 641 Answers
SOURCE: Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Posted on Jun 29, 2006
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Posted on Nov 14, 2006
  • 156 Answers
SOURCE: thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Posted on Feb 25, 2008
  • 1073 Answers
SOURCE: Kenmore F/L Washer Model 41743142200 tub loose
you may have a dampening shock that is bad
Posted on May 08, 2008
  • 1937 Answers
SOURCE: I have a model 417-44042400 front loader. I
See the following site for Sears manuals for your washer:
They are PDF files that can be downloaded and printed.
http://www.managemylife.com/mmh/owner_manuals/search?query=417.44042400
Posted on Apr 05, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
What causes our front loading washer to make exceeding loud noise when it enters a spin?
Sounds like a bearing seal is going. The seal has ruptured and grease of seeping out. The loud noise is the bearings rubbing against each other without adequate grease to reduce the friction. Failure will come soon if it is not fixed. The vibration is coming from the friction and possibly damaged ball bearings .
Mar 11, 2015 | Washing Machines
LG Washing Machine makes a groaning sound.
Its most propably bearings on the drum,normally the seal in front of the bearings is leaking ,allowing water into the bearings, which destructs them..
It is bigger job to take the drum apart but do'able with basic tools.
If possible, source the seal and bearings beforehand.
Another factor can be overloading,try lightening the loads first..
Oct 05, 2012 | LG Washing Machines
Loud banging noise during washing cycle. Sounds like agitator is slipping,then banging. No noise during spinning cycles.
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
This is your Agitator:
http://www.repairclinic.com/Appliance-Parts?s=t-WBSR3140DW-%3d%3dc201
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WBSR3140DW-%3d%3dc239i1195917&PartID=1195917
This part is the most likely cause of the noise.
Thanks for using FixYa.
Kelly
Mar 07, 2010 | GE WBSR3140DW Top Load Washer
My washing machine is making a loud screaming noise..it's still washing my clothes but when it's on the spin cycle it's almost unbareable.
As the washing machine is making a loud noise I think the first thing I would request you to do is lift up the washer from the front, remove the belt and check the pump by rotating the pump pulley manually. If does not move freely then replace the pump.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Estate ETW4400VQ Top Load Washer
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Groaning noise in Maytag 4000 washer
yea probly passed warr from manu , if its rear bearing issue gonna run alot ot fix BIG JOB!
Feb 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore Front Load Washer Logo
60 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
