Question about Moen Posi-Temp Single HandleTub And Shower Faucet
I installed a moen posi temp faucet, but it never had good hot water flow. If I remove the cartridge and turn on the hot water then I have plenty of hot water shooting out. The cold water comes out fine. I replaced the cartridge with a new one and nothing has changed. Any solution?
  • 343 Answers
In most cases, the knob has been installed upside down. To correct this simply:
  1. Remove handle cap and the Phillips screw under the cap.
  2. Pull the handle off the faucet.
  3. Now replace the handle, only this time, make sure the point of the waterdrop handle is pointing downward to the six o'clock position.
  4. Replace the Phillips head screw and handle cap.
The next reason could be' It is possible that the balancing spool is stuck due to non-use. Replace the cartridge to correct this situation. To prevent future issues, use the faucet at least once a week.
You could try gently tapping the valve and run in under hot water in a sink and see if any deposits come out. It could be from hard water, rust, minerals etc.
I had a problem with one before and contacted Moen and they sent me a new valve for free
Call: 1-800-Buy-Moen (1-800-289-6636)
Or you can email them at the link below.
http://www.moen.com/consumer-support/contact-us
I believe this should answer your question, Thanks for using FixYa
Posted on May 22, 2011
  • Carl W May 22, 2011
    If you just installed it recently there could have been debris in the pipes when you connected it. Did you flush out the lines before putting in the cartridge, if not a small piece of deris could be keeping the positemp valve from working properly. Hope all this information helped you with the problem.Thanks again for using FixYa
Moen single lever shower handle gives only hot water
A bit more information is needed; is this a Moentrol or a Posi-temp valve? You will need to shut water down to the shower. If it is a Moentrol, it could be an issue with either the cartridge or the pressure balancing spool. If you are at least getting water, I am going to assume that it is a Moentrol.
You will need to turn water off to the valve. Pull the cartridge and examine as to whether or not debris is blocking the supply holes of the cartridge. If your valve has built in shut off screws, you can slowly turn water on to clear any debris that may be inside the inlet port. I typically use a piece of PVC to go over the valve body so that water does not leak between the wall and the shower. Again, just turn water on enough to start it flowing.
If you do not notice anything amiss with the cartridge, it could also be the pressure balancing spool. If that is on your valve, it will be a flat head screw about the size of a nickel. Water will need to be off for the removal of the spool as well. Again, you will be looking for debris that is blocking water flow.
If this is an older Moen faucet, you may just want to replace the cartridge while you have it removed. If it is a push/pull, it is a Moentrol. If you have to turn the handle for water to come out, it is a Posi-temp. In my area, the cartridges run from $20-$40. However, Moen does offer lifetime on their cartridges. Lately, I have had a few more hoops to jump through to get the replacement cartridges from Moen, but they are still very pleasant to deal with.
Oct 16, 2014 | Moen & Posi-Temp Single Handle Shower Or...
Water on/off is in the wrong position after changing the moen cartridge in my shower
Put your cartridge back the way it was originally. By rotating 180 you reverse the hot and cold. Leave the handle and plastic adapter off. Turn on your water supply and turn valve with the plastic adapter until the water is shut off. Remove the adapter and install it with the set screw for handle facing down. Put your handle back on and that should take care of problem. (I did the exact same thing as you today....small world)
Feb 16, 2013 | Moen Posi-Temp Single HandleTub And Shower...
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
Hot water trickles in swhower--works fine on other faucets--cold h2o flow fine
Clogged galvanized pipes. Replace with Pex or Copper lines. Or bad Moen cartridge- see department store for replacement or call Moen direct. You can get the # from gethuman.com
Nov 11, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Get hot water only....when rotated to cold get nothing....replaced cartridge but still the same.....shower has been unused since house was built
If you don't have easy access to hot and cold line, where you can disconnect and check for flow to faucet, You can try turning off incoming water supply, remove cartridge, and shut off hot outgoing at water heater, then slowly open incoming (cold) water supply only and see if cold flows from faucet with cartridge removed. At least that will confirm flow faucet, then go from there.
Sep 19, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Installed new Moen posi-temp cartridge. Hot & cold water is correct but water will not shut of*** the way.
I just had the same experience, except I used a non-Moen cartridge. (It was from Ace Hardware, and Ace told me that Danco was the manufacturer.) When I pulled the cartridge back out, one of the two hard plastic seals on the side of the cartridge had torn, presumably on the sharp metal opening on the water supply pipe. I'm guessing there's something wrong with one or both of the seals on your new cartridge.
Jul 13, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Low water pressure. New installation, replacement
posi temp's usually have shut off valve's to the left and right of center.remove trim plate and check,make sure they are turned full on.i am pretty sure they are quarter turn type,and they have a screw driver slot,when there horizontal they should be fully open
May 09, 2010 | Moen Posi-Temp Single HandleTub And Shower...
I replaced my Posi-Temp cartridge for the shower faucet. While the faucet now works fine, the pipes bang (water hammer effect)in the vicinity of the faucet every time someone shuts off the hot water. They...
no one ever really figured out why this happens, but you can purchase a "hammer arrestor" to solve this problem. they work good and believe it or not they are best installed at shower valve. good luck
Jan 22, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle bathtub faucet
Something is caught in the stem. Make sure the stem is free of debris. Also check that the valve or cartridge is intact.
Jul 02, 2009 | Moen 2919 Chateau Two Handle Tub and...
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen Posi-Temp Single HandleTub And Shower Faucet  Logo
138 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
