My pandigital will not come on. I have tried resetting. When plugged in the charge light is red, then turns green. Do I need a battery, and if so , I do I change it, and what kind?
    Sergeant:
  • 223 Answers
Thank you for using FixYa
The battery is not consider user replacable, however it can be replaced. You have to pry the case apart and try not to crack, break or chip the case. Once you have the back off you can clearly see the flat battery and it can be pryed out. If you have never done this kind of work it is easy to break something, so be very careful, Once you have it out you can see numbers on it and search the internet for the part. Of course you may void your warranty. I found one on ebay but it may be gone by now.
http://cgi.ebay.com/Pandigital-Novel-7-Color-eReader-Li-Polymer-Battery-/270750876561?pt=US_Tablets&hash=item3f0a028391
I hope this was useful and please comment if this was helpful to you.
Posted on May 22, 2011
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Why does the battery flash from red to green while charging?
If it changes from red to green and stays green while being charged, it is just a sign that it is being charged and there is nothing wrong.
If it flashes back and forth between red and green while charging, there might be something wrong with your charger's connection.
Jan 26, 2014 | PANDIGITAL 7 Android with 2GB Internal...
How do i unfreeze my android tablet
My Pandigital screen is frozen, all I get is a green android with a triangle with an explanation mark inside it. How do I reset this?
Oct 28, 2012 | PANDIGITAL SuperNova
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
My pandigital won't turn on, I was reading a book, turned it off, charged it, now it won;t turn on
DON'T RETURN IT YET....If your white Pandigital Novel won't turn on. Don't return it yet. I have one of these, and so does my daughter. Both of us have experienced the frustrating "screen freeze," then the subsequent shut-off and inability to turn back on. I tried the "reset" button first, then I tried all of the crazy "flashes" that are listed in some other posts that require another mutant hand (holding down power, volume and pushing reset all at the same time). None of this worked. Then I would plug in and it the red indicator charging light would come on, seemingly charging it. I was still unable to turn on, no matter how long I left it charging. THEREIN lies the problem. Here's the magical solution (to both of our "freeze-ups" anyway): Unplug it and let it go completely dead. Take it OFF the charger and let it sit for like 4 days. (I know it's hard to live without your baby...but this worked for me). I'm not sure how or why this worked, but my guess is that without pulling off the back and pulling out the battery (which i'm guessing would involve some prying and might void any warranties and/or return possibilities), this allows the li'l "engine-that-could" processor in these babies to reset. After you're confident that the battery has gone completely dead, first plug it in, then turn it on. Both mine and hers started back up like a champ--complete with all of our books, etc. Give it a try before you return it.
Feb 06, 2011 | PANDIGITAL 7" Digital Photo Frame With...
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Charging lights turn red and green...But camcorder will not power on
All right if you have the same problem that i had what you need to do is take the battery out the take the memory card out the put the battery back in then try and turn it on if it works then put the memory card back in and it should be fixed
Apr 29, 2009 | Cameras
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Computers & Internet Logo
222 people viewed this question
David Payne
David Payne
