Question about HP Media Center m7250n (ED842AA) PC Desktop
Configurate how can i configurate my computer
  • 781 Answers
Wow.. this question is way way.. wide open.. it's like asking how do you raise a child to be a good person.... there are quite a few things that can be said...
my suggestion... take your time knowing how to do what you need your computer to do... as you learn you will be configuring the computer to do as you say.
there are zillion of little things you can do to configure it just the way you wanted... try to post a specific thing you want to do and I'll help you as much as I can.
Posted on Sep 21, 2008
Backup the configuration of fortigate
Administrators can back up the FortiGate unit's configuration file from the System Information widget. Select Backup in the System Configuration row, to back up the firmware configuration file to a local computer, USB disk or to a FortiManager unit.
You should always back up your configuration whenever you make any modifications to the device configuration or performing any firmware updates or changes.
Local PC Select to back up the configuration file to a local management computer. FortiManager Select to back up the configuration file to a FortiManager unit. The Central Management settings must be enabled and a FortiManager unit connected with the FortiGate unit so that the FortiGate unit can send the configuration file to the FortiManager unit.
To enable central management, go to System > Admin > Settings. USB Disk Select to back up the configuration file to a USB key that is connected to the FortiGate unit. Full Config Select to backup the full VDOM configuration. This appears only when the FortiGate unit has VDOM configuration enabled. VDOM Config Select to backup the only the VDOM configuration file. This option backs up only the configuration file within that VDOM. Select the VDOM from the drop-down list, and select Backup. Encrypt configuration file Select to enable a password to the configuration file for added security. Password Enter the password that will be used to restore the configuration file. Confirm Re-enter the password.
Feb 14, 2014 | Fortinet, Inc. FortiGate 80C (FG80CBDLUS)...
Tip
Configure Wireless Zero Configuration to configure wireless connection on XP...
Configure Wireless Zero Configuration to connect to wireless network on your wireless XP computer.
Below mentioned steps will help enable Wireless Zero Configuration on your XP computer and achieve wireless connectivity. These steps applies to your XP wireless computer (Desktops and laptops) with external or built in wireless cards.
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight the SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button. You should have successfully established a wireless network connection.
The above steps will help you in the configuration of wireless connectivity if you are not aware about the settings of wireless connection utility installed on the computer.
on Mar 18, 2010 | Computers & Internet
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Apr 10, 2013 | D-Link Computers & Internet
How to configure router & switch
You shouldn't have to configure anything except the PC's should have IP and gateway set to auto.
Here is how it works:
A router connects two separate networks and manage the traffic between them.
In most home network applications the router connects your local group of computers and devices known as the LAN with the Internet, commonly called the WAN or Wide Area Network.
The router usually assigns unique Local IP addresses to all of the devices connected to it via a service known as DHCP. The addresses assigned by your router are private addresses http://en.wikipedia.org/wiki/Private_net... and are not routable across the Internet.
Dynamic Host Configuration Protocol (DHCP) is an auto configuration protocol used on IP networks. Computers that are connected to IP networks must be configured before they can communicate with other computers on the network. DHCP allows a computer to be configured automatically, eliminating the need for intervention by a network administrator. It also provides a central database for keeping track of computers that have been connected to the network. This prevents two computers from accidentally being configured with the same IP address. http://en.wikipedia.org/wiki/Dynamic_Hos...
Your cable or DSL modem will get a Public WAN IP address from your ISP's DHCP service. These public IP addresses are leased in blocks by your ISP and are Internet routeble. The modem is connected to the WAN port on your router. The router will manage the traffic between the devices on the LAN and the Internet.
If your 5 port switch is connected to one of the router's LAN ports and router's DHCP is on then it will configure the clients attached to It automatically.
Feb 04, 2013 | Computers & Internet
Invalid configuration information
Start your computer and after the BIOS screen disappers , begin rapidly pressing PF8 until the Windows Boot Options appear. You should see "Safe Mode", "Boot from last valid configuration", and "Normal Mode", and maybe a few others. Select "Last Valid Configuration." Computer should sucessfully boot.
Jan 17, 2012 | Microsoft Windows XP Home Edition...
I have a wrt310n router and cannot get internet connectivity when trying to configure a wn2000rpt
is your wn2000rpt connected to the wrt310n or the modem? are you using DSL modem? if so you may need to call in DSL service provider to configure something on their side first. for router configuration, you need to use static IP on your computer in the same subnet of the default IP address of your router. did you configure it yet? if you already get in the configuration page, then try to use DHCP only on one router. if you are using DSL modem then you might need to choose PPPoE as the connection type. Then check the cable and reboot your computer. If your computer is configured as receiving DHCP IP address then make sure there is a DHCP on your router. Anyway, if you tell me the details of your modem and router make, model and connection and the operating system on your computer I can tell you more.
Apr 23, 2011 | Computers & Internet
I am trying to configure my DIR-615 D-Link router to another computer that has vista.What can i do to get the computer to pick-up this router so it can be configured?
Connect a LAN cable from the D-Link to your computer's LANport, open a browser and enter the D-Link's configuration URL. OR open thebrowser on your laptop and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now go to the wireless settings eg. SSID, WPA or WPA2 encryption key.
Now you need to configure the wireless card in the VISTA computer with the router's wireless settings for this computer to communicate with the D-Link router.
Feb 20, 2011 | Computers & Internet
How to connect 5.1 intex speakers
your problem is you have a very nice 5.1 speaker set but you have not configured your system to use the 5.1 configuration.
if you are using the realtek drivers, then try to open the configuration panel,
and in the control panel try to change the default sound configuration to 5.1 surround sound configuration. then all your speakers will work.
hope this helps
Feb 05, 2010 | Logitech X-530 Computer Speakers
Rear speakers did work but don't know
Have you tested the speakers on another computer? Have you installed all of the software including the Creative Audio console?
If yes to both, you need to go into the Creative Audio Console and select the speaker configuration tab and use the drop down menu to choose the speaker configuration you are using. They offer 2/2.1 4/4.1 5.1 6.1 and 7.1 options. If you don't select the speaker configuration, the speaker ports for the other channels are disabled.
There are also options in various media players for speaker configurations. Most don't auto configure. At least not with the Creative Audigy cards.
Hope this helps.
Cheers
Sep 30, 2008 | Dell ADA745 Computer Speakers
HP Media Center m7250n (ED842AA) PC Desktop Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
