Question about Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
CLOTHES WONT DRY. IT GETS REALLY HOT INSIDE. THEY SEEM WETTER AFTER IT RUNS FOR AWHILE. TAKES PROLLY 3 HRS TO DRY.
  • Maytag Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Aug 15, 2011
    Brigadier General:
  • 3,301 Answers
Check the vent pie for debris ,, the vent allows moisture to escape the drum,, if it can't the clothes will get hot or warm showing the machine is heating up it just can't vent that moisture out .
Posted on May 22, 2011
4 Suggested Answers
wmsfarris
  • 22 Answers
SOURCE: the dryer does not stay hot
You probably have a restriction in the exhaust somewhere. Check vent to outside , if that is okay remove hose from back of the machine and look for lint buildup in hose and machine. More than likely the problem is in the duct in the front panel where the lint screen goes. To check and clean this you will have to remove the front panel.
Posted on Apr 04, 2009
  • 77 Answers
SOURCE: Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
Posted on May 12, 2009
milten1
  • 1304 Answers
SOURCE: smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Posted on Oct 11, 2009
Why do clothes take a long time to dry even if dryer is heating?
One basic reason is your washer could NOT be spinning most of the water out, therefore your clothes are wetter than they should be, thus taking longer to dry:-)
Jan 22, 2015 | Whirlpool Dryers
I have a GE dryer that won't dry our clothes. It heats up, but water is all over the inside door and the lint that comes out of the hose in the back is wet! The outside of the dryer (the top in...
It really sounds like your washing machine is not spinning the clothes out enough. Have they been wetter than usual lately? The dryer could just be struggling to keep up with the heavier / wetter load as there is no reason for it to create moisture on it's own.
Oct 06, 2010 | GE Dryers
Dryer gets hot but takes along time to dry
Make sure the lint filter is clean. If it is make sure the hoses leading from the dryer to the outside are not clogged. It sounds like it is not getting prober airflow through the tub.
Jun 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My kenmore series 80 model # 110.74852400, takes forever to dry. the flame comes on, but doesn't seem to stay on for long. please help. thank you
my kenmore dryer ignites runs for awhile then wont reheat. let it sit for a few minutes and it will heat again for awhile
Apr 20, 2010 | Kenmore 72802 Gas Dryer
My dryer runs and gets hot but cloths don't dry.
Your problem may be attributed to a clogged exhaust system (e.g.: clogged inside the dryer's vent, flexible vent behind dryer clogged and/or clogged inside wall, etc.).
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
Wont dry clothes is hot inside dryer but takes 3 or 4 cycles to dry load
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Sep 26, 2009 | GE DBSR453EBWW Electric Dryer
Kenmore dryer hot, but doesn't dry clothes...also spueaks
Sam,
A dryer function is really simple:
Gets hot, boils left over moisture from clothes and it needs to blow it out.
If it is getting hot and it is turning - Then your problem is in the exhaust system.
Check all pipes that carry moisture/steam/vapor out of your machine and make sure is free of any restrictions.
Good Luck
Aug 18, 2009 | Roper RES7646KQ Electric Dryer
Dryer wont dry clothes
Vents can fool you sometimes they seem to be ok but still cause problems. Try running with vent unhooked from machine one time and see if it works ok.
Check for leaks air leaks around the door or anywhere else.
Jun 10, 2009 | Whirlpool LER4634J Electric Dryer
Maytag dryer wont shut off
Is it an auto sensor shut off? If so, it may be that your hose is plugged and so actually takes that long to dry the clothes.
Mar 13, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Open Questions:
See all Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Questions
Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
232 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
