Question about Samsung SyncMaster 214T 21.3" LCD Monitor
I have vertical banding on my SyncMaster 216bw. I then had a power surge which blew 5 capacitors. Then the screen would not power on. I replaced the capacitors but the veritical bands still remain.
    President:
  • 1,216 Answers
Either some capacitors were not replaced properly or you have nor replaced some of them.
The capacitor you need to replace will have a bulged top(swollen).
Try and change the refresh rate of your monitor by following these options--
1.) Right click on your desktop.
2.) Select Properties.
3.) Click on the Settings tab.
4.) Click on the Advanced button.
5.) Open up the Monitor tab.
6.) Manually increase the Screen Refresh Rate to 75Hz(60Hz if it is max), which is measured in Hertz
Please check out the complete procedure with pictures on this link---
Samsung 215TW Capacitor replacement
Posted on May 22, 2011
Syncmaster 216bw monitor..stuck in power saver mode..power light blinking
Did you try this monitor with another PC yet? VGA cable connectors are properly seated?
This model (same chassis as the 223w) is known for haing bad caps in the power supply/inverter board as shown here:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20223bw/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 26, 2011 | Samsung SyncMaster 216BW Monitor
Samsung 216bw does not turn on initially. It starts to, then goes black. If I turn it off and back on several times, it finally stays on.
The problem you are having is an indication of a failing power supply. There are parts called capacitors that fail and cause the power supply to not start up correctly. When you keep pressing the start button the voltages coming out of the power supply will finally stabilize and the monitor will display a picture until you turn it off then you have to start all over again. The power board can be easily repaired by replacing the ad capacitors. You can get information about the parts needed here: http://www.ccl-la.com/catalog/product_info.php?products_id=138 The repair will require you doing a little soldering but its very easy.
I hope this helps, if so please please rate our solution.
BuddyMc
Jul 06, 2011 | Samsung SyncMaster 216BW Monitor
No power in my samsung 216bw monitor
Look for bad caps, it uses the same board as 223ww as shown in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
Oct 20, 2010 | Samsung SyncMaster 216BW Monitor
When I press the power button on my Samsung Syncmaster 216BW it goes to source test but does not turn off the monitor
That is main board problem may be the EEPROM is defective could cause of cannot save or store current settings. You need to replace your main board to fix this problem.
Sep 09, 2010 | Samsung SyncMaster 216BW Monitor
Need Synmaster 216bw driver
Here is the driver download from SAMSUNG website
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=216BW&prd_ia_sub_class_cd=P
Just click on the driver, it is the same one as you listed '20070515103345609_SM223BW'
No need to uninstall the old driver, all the driver doese si to allow you to set the resolution that is not listed in the microsoft video resolution lists.
Jun 29, 2010 | Samsung SyncMaster 216BW Monitor
SyncMaster 216BW Monitor: it works for 1 hour suddenly the image goes and af...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Samsung monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 16, 2010 | Samsung SyncMaster 216BW Monitor
Backlight going bad?
This is not the backlight its the power supply board. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ The repair consists of replacing 5 capacitors on the power supply board. If you can solder then you can do this repair. If you don't want to do the repair we do offer a repair service, you can get this information here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 28, 2010 | Samsung SyncMaster 216BW Monitor
The blue light just goes on and off steadily
Change the 3 capacitors ot the power supply-you will see them puffing up on top and brown residue on top.shuold be barked on the board as c822,23,24. They are 10v 1000mf 100 Degree capacitors.
Oct 08, 2009 | Samsung SyncMaster 216BW Monitor
Samsung 216BW
All of your mention symptom. see example of bad caps: http://s807.photobucket.com/albums/yy352/budm/Samsung%20Syncmaster%20214T/
Replaced all those caps (not hte big on in the primary circuts) with PANSONIC FM or FC series from DIGKEY.COM
Oct 29, 2007 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 214T 21.3" LCD Monitor Logo
78 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
