Question about Cell Phones
My mobile is saying pc connection, but is it not connected to pc and any devices. What should I do?It is also be charged by itself, thanks
  • 255 Answers
Check your phone settings and adjust the usb options to mass storage mode.This would solve your problem for sure.
Posted on May 22, 2011
I require PC suite with win7 compatebilty for Motorola rokr e6 phone to connect laptop for internet uses. Please help me I am searching last 3 months Thanks & regards Arvinder
all corresponded motorola mobile has a specific driver itself.
might some driver is not install or properly installed...such as P2K driver etc.
look for the right driver to connect,well as what i've experience connecting motorola on win7 OS,i might say there's a little be hard to connect or recognized the mobile thru pc or laptop.
hope it helps.... please rate me..thanks
Jun 03, 2011 | Cell Phones
Will not turn on
If your device is not having power, there are 3 factors to be checked. The battery, the charger and the device itself. Run a test on the three factors and you will be able to tell which has the fault and how to solve it.
Insert the battery in another device, then you try to charge it for some time, lets say about 2 hours, then you try to power the device on to see if it will power it on, if it powers it on, then it means your battery is alright. Put it back in the gps device and power it on.
Then you connect you charger to another device to see if it will charge. If it charges it, then it means the charger is alright but if it does not charge, then it means the charger is bad and need to be replaced with a new one, then you connect the new charger to your device to see if it will charge it and power it on, if it charges and powers it on, then that solves the problem, but if it does not, then you need to test the device itself.
Then you further go ahead to test the device by connecting it to a computer and its normal charger, then it means there is a problem with the connection port of the device is bad or there is an internal problem somewhere.
Hope this helped. Thank you for using fixya
Jan 20, 2011 | Garmin GPS
When I connect to my computer it gives me a message saying device not recognized
Merry Christmas!!!
Greetings for the festive seasons!
It seems like you are connecting a USB device to our computer. USB is a PNP bus. whenever you connect anything to USB, some handshaking is done by the OS with your USB device, so as to recognise its class (if it is a storage device or printer etc,) and other details like its manufacturer, capacity etc. If, for any reasons, this handshaking is not done, this error is raised.
to solve this problem, try following things
1. change cord and try again.
2. If it is a USB hard disk, try twin USB cable. where single USB end is connected to the USB hard disk, and twin USB side (both the pins) are connected to the. PC. It happens, when device is consuming more power, so some additional power is needed to drive it.
3. If it is a mobile, printer or camera, install drivers first and then connect the device.
4. If you are connecting it to front USB ports and the wiring inside is made incorrct. This nmay cause damage to any device you connect to that port. if any other product is working on that port, then simply rule out this probability
5.Try different port, as the device you are using may be using higher version (USB 2.0 or USB 3.0). but this is rare case, as PC itself will prompt you by "This device can work faster"
6. Device itself is faulty. try connecting, similar device to your PC and confirm.
If it is not solved, give brief description of what are you connecting to your PC and what have you tried before.
Dec 27, 2010 | Computers & Internet
How to connect in computer? what connection do i need?
You can connect your mobile to PC by using USB cable and PC suite.
USB cable will be provided with the mobile itself.
You can download the PC suite from below website.
http://www.software112.com/products/samsung-pc-studio.html
Install it and you can connect your mobile to PC
Thank you
Aug 07, 2010 | Samsung SGH-E251 Mobile Phone - Black
My nokia bh 213 bluetooth was working with nokia E63 , all of a sudden it is not , the bluetooth is charged and green light is flickering , when tried to pair thed eivce it says the device not found , what...
Thanks sleekycupid.. Even i had a same problem just followed the steps you said.
Step 1: Switch off the bluetooth device.
Step 2: Charge the bluetooth device.
Step 3: Then hold the device button till the green indicator blinks faster than normal.
Step 4: Now try to pair the device from your mobile.
Step 5: Mobile will ask you a passcode, press 0000 and enter.
You might not follow step 1 and 2. Just start from step 3.
Enjoy!
Mar 13, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Cannot connect Samsung GT-S5230 tp PC
TRY TO CHECK THE SETTING OF YOUR PHONE REGARDING CONECTIVITY.
Aug 21, 2009 | Samsung U900 Soul Cellular Phone
While I connet to internet using Nokia 7610 as a GPRS modem with my PC any one calling from any phone found that my cell phone is switched off.
when u connect with pc then ur mobile need more charge so u need full charge ur mobile battery. or u can connect charging connection when u connect with pc. thanks
Jul 23, 2009 | Nokia Cell Phones
How to connect blue tooth from pc to samsung cameramobile?
hi there!
While the specific user interfaces implemented by manufacturers may differ from device to device, there are still some very basic steps to go through in connecting two devices for the first time. Users should always conduct the pairing process in a secure environment.
Charge the Devices
If the devices are new Bluetooth devices, often they must be charged before they can connect or turn on. This is particularly true of new Bluetooth headsets, which must be charged before use.
Power Up the Devices
Power up the devices you are trying to pair. With some devices, like Bluetooth wireless headsets, powering up the device also initiates the pairing process.
Turn the Bluetooth Functionality On
The Bluetooth functionality in a device may or may not be turned on when you receive the device. For many computers, users will need to turn the Bluetooth radio on from the control panel or system preferences.
Make the Devices Visible
As a security measure, some devices allow the Bluetooth functionality to be off, hidden, or visible. When trying to connect devices, users should make the devices visible so the devices can discover one another. After the devices are paired, users can set the devices to hidden if they have concerns about their devices being discovered by others.
Place Both Devices in the Connection Mode
After both devices are charged, powered up, and the Bluetooth functionality is turned on, each device needs to initiate a communication session. Typically, in a connection between two devices, one device acts as the “host” and the other device acts as the ”guest.” The device in the host role is the one with the user interface from which most of the connection setup will take place. A device can be in the host role with one device and in the guest role with another device. For example, in a phone and wireless headset pairing, the phone is the host. However, in a phone and laptop pairing, the laptop is the host.
Enter the Passcode
After the two devices have discovered one another, the user will be asked to enter in a passcode in one if not both of the devices. In some cases, like with wireless headsets, the passcode is a fixed passcode assigned to the headset by the manufacturer. In those cases, the user enters the assigned passcode into the host device. The user will find this passcode in the user manual. In other cases, the user will be able to enter in his/her own passcode. In these cases, the user will enter the passcode once into each device. It is highly recommended that users employ an eight character alphanumeric passcode for the one-time pairing process. After the passcode is entered, the devices will validate one another and complete the establishment of a trusted connection.
Deleting or Disconnecting Trusted Devices
When should a user delete or disconnect a trusted device? If one of your Bluetooth enabled devices is lost or stolen, you should unpair that device with all the devices to which it was previously paired.
How do you unpair or delete a trusted device? For devices like a mobile phone or computer, the user should go into the device connectivity settings and find the list of trusted devices. The user should then have the option of adding a new device or deleting a trusted device. Highlight the device you want to delete and push the delete button. A device like a keyboard or mouse, which only has a button or switch as a user interface, can only connect to one device at a time. To delete its previous trusted device, the mouse or keyboard just needs to be connected to a new device
Or you can try this:
Bluetooth Mobile Phone to Bluetooth Personal Computer
  1. Power up both the mobile phone and the personal computer.
  2. On the PC, open up the control panel and find the Bluetooth Device Wizard. This will assist the user in setting up a Bluetooth connection between the PC and trusted devices.
  3. Ensure the Bluetooth connectivity is turned on in the PC.
  4. Find the connectivity settings of the phone. Make sure Bluetooth connectivity is on and visible.
  5. On the PC, choose to find and add a specific Bluetooth device.
  6. Of the devices found, pick the mobile phone with which to pair.
  7. PC will generate a PIN code.
  8. Mobile phone will ask if you wish to be connected to the PC.
  9. After the user answers in the affirmative, the user will be prompted for the PIN code on the mobile phone. Enter the PIN code into the mobile phone, which the PC generated.
  10. Allow devices to complete the establishment of a trusted link.
  11. If prompted on the PC to choose the Bluetooth services, the user may have several services available. The user may be able to sync the phone and PC. The user may be able to set up dial-up networking (DUN) preferences so that the user can use the mobile phone as a modem for the PC over the Bluetooth connection. The user may be able to transfer files, like pictures or business contacts, between the mobile phone and the laptop.
  12. After choosing which services the user wishes to enable, the user can then finish the connection and exit the setup on the PC.
better yet go to this website: http://www.bluetooth.com/Bluetooth/Products/Devices/Generic_Pairing_Instructions.htm
Feb 16, 2009 | Samsung SGH-E251 Mobile Phone - Black
Win Mobile Device 6.1 Vista will not Connect
Slmgato: have you tried to delete the old pairing on wmdc?
also to the other users: check the usb charge port on the tilt. Make sure it has not been bent or the pins have not been damaged. My tilt recently was damaged and now i can't charge or sync, but i can buy the replacement port for about 10 bucks and solder it myself.
Mar 18, 2008 | AT&T 8925 Tilt Smartphone
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
