Question about Pro Series VWH3610 Series Viking 10" x 36" Wide Wall Mount Hood with Standard Interior
Blower does not turn on lights work fine - Pro Series VWH3610 Series Viking 10" x 36" Wide Wall Mount Hood with Standard Interior
  • 10,865 Answers
Hello gagg... the problem could be the switch or it could be the blower motor. Open it up and check to see that you have power to the switch. then bypass the switch to see if the blower motor works. if the blower works that way you will know it is the switch. otherwise it is the blower motor. both parts are common and available from viking. joe
Posted on May 31, 2011
2001 Olds Intrigue A/C cycles on and off when A/C is turned on ?
If ambient temperature is 85F or above when it cycles that way, it is an indication that your refrigerant charge is low.
May 17, 2015 | 2001 Oldsmobile Intrigue
I have a 1998 Plymouth Grand Voyager. Last week, the rear blower stopped working and the brake lights no longer function. All other lights work. The front blower works just fine. All fuses are...
The rear blower and the brake lights might not be related troble. The rear blower has a ballast resistor that can fail and it's next to the blower motor in the rear heater housing. The blower motors are also known to go bad so wrapping on it with it turned on might( wake it up) and it'll start woring again as a poor connection shaken or the worn motors brushes shaken down where they make connection again. Then you say the rest of the lights work do you mean that the brake light bulbs come on with the hazard swich entergized? or do the rear lights just light yellow turn lights only? I'd check or even replace the brake light buld=bs before I'd do anything else.their are other things that don't work if the fuses were involved and the same goes for the heater rear blower as the front blower uses the same fuse.
Sep 23, 2011 | 1998 Plymouth Grand Voyager
Blower motor not working. fuses appear to be ok. was working fine yesterday. any ideas?
Test the blower motor, turn on the switch and then with a test light conect it something that is grounded. Check for power at the harness, then connect the test light to the power side of the battery and test for grown at the harness if you have power and and ground replace the blower.
Feb 11, 2011 | 1995 Ford Mustang
1997 Pontiac Grand Prix GT; Elec problem with fan
Replace the blower resistor that is mounted next to the blower motor on the passenger side of the vehicle.
This will restore correct blower operation and I suspect it is also back-feeding voltage resulting in your electrical issues.
Two screws hold the blower resistor into the heater case and it is very easy to replace.
Good luck
Mar 11, 2010 | 1997 Pontiac Grand Prix
2004 impala a/c blower not working
No it can not.
You have a couple of actuators that have gone out. The driver temp control. And the air inlet actuator.
And I don't fallow your statment of "my a/c blower went completely out. I tested the blower and it works fine".
If the blower went out, then what do you mean it works fine? Are you talking about air delivery or it just quits blowing all together?
Jul 01, 2009 | 2005 Chevrolet Impala
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
2000 grand prix day time running lights/blower not working correctly
Believe it or not, but it was a bad ignition switch. I the switch apart and found about 3 different and one in particular that were burned pretty bad. Must have been the circuit that controls the blower and DRL? Found the solution on another blog. I put a new switch on in about 1.5 hours. I does take a couple special tools, very small female torx sockets. Other than that pretty easy.
May 22, 2009 | 2000 Pontiac Grand Prix
Heater\AC no air in front 05 suburban
ase mechanic:
Sounds like a problem with the front blower motor. there is a blower motor resistor for the front blower motor that controls the speed of the blower and tends to go bad or fry out the blower motor. thats the most likely scenerio since you stated the control head was lighting up and responded to button changes.
Jan 29, 2009 | 2004 Chevrolet Suburban
1993 Varvan, Not Turn Signals, No Heater Blower, And AIr Bag Light Now On
boy, that sound like a major circuit to cause all that. either a main fuse under the hood or a main circuit wiring harness connector. there are no unfused circuits that could indicate a short unless there has been past fuse blowing problems
Sep 28, 2008 | 1993 Dodge Caravan
Pro Series VWH3610 Series Viking 10" x 36" Wide Wall Mount Hood with Standard Interior Logo
67 people viewed this question
Top Pro Series Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Pro Series Electrical Supply Expert? Answer questions, earn points and help others
