Question about Garden
What do I have to change to the inside of my mastercraft vac to pick up water?
    Brigadier General:
  • 3,301 Answers
Remove the paper filter and go for it, thats the only difference between the wet and dry applications
Posted on May 22, 2011
My shop vac wont pick any water
I assume it is a wet or dry vac, if not thats your problem. If it is you always take the filter off when you are picking up water with it. B sure 2 put filter back on when sweeping car etc. IF that dont work, take hose off, and run broom handle through the hose 2 see if there is a clog. Good luck................
Mar 31, 2015 | Cars & Trucks
I am using a wet dry vac and it is picking up water great but is spraying quite a bit of water out of the top part of the tank. The tank is no where near full, maybe 10%.
I have seen where so do not know that certain pieces of vac and be taken apart. Open and unscrew to look inside to see whats loose causing that problem.
May 22, 2014 | Dirt Devil Vacuums
Mastercraft com
It should have a screen in the pick up tube inside the tank and it should also have a water separator mounted inside the bilge somewhere. The carb may also have a filter in it if it's not fuel injected.
Aug 15, 2013 | Ford Cars & Trucks
We inherited the shopvac 16 gallon. I bought the required filter (foam) but the dust blows back from the blow hole. Am I missing a part?
The foam filter is for use when using the vac. to pick up water. Now you should have a paper filter for picking up dry material.If possible you may want to look inside of one at the store. Hope this helps.
Jun 23, 2011 | Shop Vac 925-13 Canister Wet/Dry Vacuum
I bought my first craftsman 9 gallong wet/dry vac - i do not know how to operate it and I don't want to break anything. I have a pamphlet but it is still confusing. can I pour a few gallons of water into...
Hello again.
When it says wet vacuuming, it means that the vacuum will pick up water, not dispense it. When you are using the vacuum to pick up water, you'll need to remove the paper filter element under the motor, inside the canister, to avoid ruining it. When the filter is removed, you will see a plactic ball inside a cage under the motor. It's purpose is to float up on the surface of the water being vacuumed up, and prevent the motor from getting water into it. You'll be able to tell when the canister is full; the noise the vacuum makes will change and sound higher. Also, the suction at the hose will quit. At that point, shut off the vacuum and drain the water.
Be sure to replace the paper filter when you swap back from liquids to solids.
Best regards, --W/D--
Apr 02, 2011 | Craftsman 17026 Wet/Dry Vacuum
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
How do you purge the liquid from a shopvac
If you have picked up liquid with your shop vac , you then need to release the handles on the side and dump the liquid out of the tub. Do not worry about the top part, the ball will float up and shut off the air so no damage will occur.
Also change the filter and bag if you have either inside when the liquid is picked up.
Heatman101
Mar 14, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
I do not know how to operate are hoover steam vac
pull out water container, fill the inner "bag" with hot water and cleaning solution, (the dirty water goes outside of the "bag" inside of the container. First run, squeese trigger to wet area, leet sit for a minute or two the go back over it until you feel it has picked up enough of the water. It will still feel wet, but as long as it was not picking up any water when passing over the area, thats all you can do. run fans and open a window.
Jan 24, 2010 | Hoover F5886-900 Steam Vacuum
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
