Question about E-Machines W2260 PC Desktop
I had the power button replaced and the machine worked fine but somewhere between the repair shop and home we I plugged the machine in it only starts for about 5 seconds and then it shutdown. I removed the cover and notice a black wire and a white wire on a small connector that appears to connect to the motherboard was disconnected. I do not know where to reconnect it, perhaps you could tell me?
  • E-Machines Master
  • 10,073 Answers
Impossible to tell without knowing where the wires come from. I'd take it back to the repair shop and ask them.
Posted on Aug 09, 2017
  • 129 Answers
SOURCE: eMachines not powering up
You may have updated windows to a point that this old machine cant handle the revamp. Kick back to an older ops system, although that poses security risks. Your motherboard may also have given up. Best advice - upgrade, and retire this machine to the recycle bin.
Posted on Jul 18, 2008
  • 3051 Answers
SOURCE: proper connection
if u look real close to the pins on the board they will say pwd led and power sw ect ect please keep me posted if you need more help identifying these pins
Posted on Aug 11, 2008
  • 357 Answers
SOURCE: powerbutton connection wires were disconnected from motherboard
Look in the manual there is a diagram and pin connections for each wire.
Posted on Feb 06, 2009
  • 72 Answers
SOURCE: I have similar problem on an eMachines W1500
Thats your powersupply cable. look for a 4pin sloth on your mobo that looks kind of like that switch and plug it in
Posted on Jun 16, 2009
  • 191 Answers
SOURCE: Blue LED light connection from Bezel to Motherboard
red white is the pair that supplies power it should be 2pin socket on motherboard
Posted on Sep 19, 2009
Why wont my lg 50 plasma tv turn
Perhaps replace your power cord. Borrow power cord from repair shop. If it works it's the cord. Also if the TV is plugged into power bar make sure the power bar hasn't been inadvertently turned off.
Oct 07, 2015 | LG Televison & Video
When I push the power button the start button flashes on and off and touching start does not start the machine.
Better call a certified Whirlpool appliance service shop and have a tech come look at it and possibly repair it.
Apr 08, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Hi when i plug in the power cord and press the power button the power light comes on then goes off and the laptop won't start its and acer aspire 4339-2618 what can be done to fix this i try holding down...
Try removing the power cord and the battery, wait 30 seconds and then plug in the power adapter while the battery is not inserted. Then try to turn the machine on.
If this doesn't work, there is something serious wrong with the machine and it will need to be repaired by your local computer shop.
Sep 16, 2013 | Acer Aspire Computers & Internet
Interrupted power on my Pfaff sewing machine
Make sure your machine cord secure in the machine. Check your home wall outlet too since you are able to get machine running away from your home. If none of these are the issues, definitely take back for repair. Jimmy
Apr 03, 2012 | Sewing Machines
My iphone screen has gone completely white and cant do anything with it
You have one of 3 things going on here.
  1. Software related issue - If this is your case you're lucky! Just perform a hard reset and a restore by following the directions below.
Do a hard reset by holding down home and power buttons together until screen goes black. While holding down home plug the iPhone into your computer. iTunes should now prompt you to perform a restore.
2. Bad LCD - This would require warranty repair/replacement from Apple. If you're not covered you can google iPhone repair for a repair shop. If you want to do it yourself buy your parts on eBay. Not too hard of a repair if you are handy with electronics.
3. Bad Logic Board = Again if this were the issue you would have to use Apple repair under warranty or a 3rd party repair shop. You won't be able to figure out if it's a Bad LCD or Bad Logic board without swapping the LCD for a good one first.
Hope this helps,
Please rate me!
Jul 09, 2009 | Apple iPhone 3G
Screen Back light no longer works
Bad wire or a bad solder. you can have this repaired if you have the service manual of the computer as it shows the full anatomy of the machine. Or a local computer shop is always a good option.
This link below will provide common laptop troubleshooting that can be at home.
Laptop Repair 101
Jan 01, 2009 | HP Pavilion dv1000 Notebook
Kenmore Oasis washing machine is completely dead
discconect power for about 10 minutes,, then plug it back in should fix if not call repair possible control board failure ,,,,,,
Jul 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Panasonic Flat Screen TV turns off by itself
If your unit was blowing fuses you must have had an overload somewhere. Your post is not clear. Does your unit run ten minutes after unplugging and replugging it? If it does then there is still a partial short in it somewhere which causes it to shut down for protection. It could be anywhere. Some detail on what happened prior to the fuse blowing would be helpful for diagnosis. You do not sound like you would have the expertise to troubleshoot this unit. I doubt there could be much wrong with it and the cost should be minimal. Find a reputable repair shop to handle the repair. Good luck.
Jun 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
E-Machines W2260 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
