Question about Philips Televison & Video
Philips 40pfl5605h/05 to philips hts3540/12 tv to suround sound, no digital input in suround sound box, only red/white/ plugs.
  • 38 Answers
SOURCE: External Sound Card
No, that's not going to work. Digital output is just that....Digital. Your trying to send a digital into analog....won't work. Your tv don't have red and white audio out. That's what you hook to, but it still wouldn't be 5.1. Your out of luck my friend. The ONLY way you'll get 5.1 out of that T.V. is to get a 5.1 reciever with CO-AX digital input...the SAME as whats on your T.V. You can only hook-up sound to your X-FI with the line in jack using a y-connector and 1/8" stereo plug....and it won't ever be 5.1. It can't that way. Only way to get 5.1 to work on the blaster is with the tosh-link optical input cable. This too is digital, but uses optics to send it. Remember, you are playing with 2 different formats. Analog with your white/red thing you made and then digital. Digital using co-ax or optical tosh-link. Completely different.....as you now know.
Posted on Dec 05, 2008
ramon49
  • 111 Answers
SOURCE: 47'' philips flat screen does not install channels
Go directly to theback of the set via the back RCA connectors(yellow, red, white) or component video, and turn set on Aux. If it works the tuner is Messed!
Posted on Apr 08, 2009
Masurrao
  • 6 Answers
SOURCE: I hook up the red and white RCA plugs to input 1
plug the rca into the dish reciever, and into the surround sound, your audio isnt coming from the tv, its coming from dish.
Posted on Apr 11, 2009
SOURCE: lcd tv hookup
Ive got 3 samsung tv's (lcd, plasma, DLP) and I use HDMI cables on all of them. Its the only way to get the full potential out of the tv. When you use the red/white/yellow RCA cables the signal is anolog aka "old technology". Component cables are good but HDMI is the best. HDMI is a digital signal and thats what all the components that go with the tv should be run on. If your dvd player does not have an HDMI output I would suggest getting one that has that output. As for the cable box most require you to upgrade to digital cable in order to get one with an HDMI output. If you dont want to spend the money on new components and run what you have now the picture will stay mediocre at best. Good luck hope this helped
Posted on May 11, 2009
  • 5124 Answers
SOURCE: How can I connect my dvd player to a Philips
The included cable with the red, yellow and white RCA connectors is a composite A/V cable. To connect this cable to the TV, you need a SCART-cinch adapter. Then use one of the SCART connections on the TV. Note: the SCART connection does not handle HD signal.
You will get a much better picture if you buy a different cable. Depending on your DVD player, get either an HDMI cable or a pair of cables - a component video and audio cable. (Both component and the audio cable will have RCA plugs at each end. The component video has 3 plugs - red, blue and green. The audio will have 2 plugs - white and red.) Both of these will carry HD signals. Most DVD players will have at least component video and composite video jacks; some have the HDMI output. Most DVD/VCR combinations will need the composite video for the VCR and the component video is optional for the DVD signal.
I hope this helps.
Posted on Dec 24, 2010
Testimonial: "Thank you very much Cindy."
What cable do i need to connect philips dvp3520/05 to hd tv
The DVD player only has a SCART out and unless you have an European model TV it won't have a SCART input. So you have to buy a SCART to RCA cable and connect the RCA end to the TV's AV input ( Yellow to Video and Red/White to audio input )
Mar 17, 2011 | Philips DVDR3380/05 DVD Recorder
55" Philips rear projection HDTV..
that input is called DVI digital video interface it is only for video. there should be some red and white composite input jacks for the audio near the DVI connector. you will need to hookup the red and white cables from the tv to the cable box or dvd player or whatver you are using. good luck
Jan 06, 2011 | Philips 55PW9363 55" Rear Projection...
Philips dvd home theather,i didn't get a users manual,i can't get the sound to come out with the tv,it will owrk with the radio. lloyd
I will guide you through it.
Just to clarify, When you say sound out with the tv, which are you referring to:
1. DVD built into to the theatre
2. Pay TV
3. Analogue TV ( or digital TV with inbuilt set top box)
4.Digital TV with a separate set top box
Please indicate which one.
TV: ther should be several set of three RCA Sockets on the back of the tv. Look for the red, whit and yellow Phono sockets. do you have these colours and are any of them labelled TV Out or output?
Philips System: Look for an analogue in, Aux IN, or any other unused RCA (Phono) Sockets ( They MUST be red or white!)
Take a set of red and white RCA leads plug them into the OUT set on the TV, and The "INput" set on the Home theatre, select that input on the theatre and your off and racing!
Please clarify first though!
Jan 17, 2010 | Philips Audio Players & Recorders
I've bought a panasonic sound surround dvd player and want to link it to a sky+ box and tv so that sky will play in sound surround. Can you advise on the wiring configuration please?
look at the back of your tv does it have a audio out RCA jack?
it should do plug in the surround sound into that using RCA cables
if your tv does not have audio out RCA jack then you can
get a adapter which makes scart connectors turn into RCA jacks get that off ebay
plug the yellow line to the tv and connect the red and white to suround sound
but with this there are a few problems sound will only come out when surround sound is turned on and skys sound will never play out the tv
if you switch to a PS3 or something it will not play suround sound
yuo best option is the RCA plugs in the back of the tv
because you have not written the model number of the tv or the suround sound i cant help any further
Jan 12, 2010 | Panasonic Home Theater System System
I can only get the suround sound to work a dvd playing and not though tv
is the surround system connected to the cable box. normally its the aux input. if your using a optical cable it should say digital in. try inputing your surround system to either one. the wires should be output from the source(tv,cable box) to the input of your surround system
Oct 22, 2009 | Philips HTS3357/05 Theater System
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
Help! Surround Sound problems!
Since you have a surround sound system, you probably should just bypass the TV's audio.
Connect the red/white plugs from your digital cable box to one of the inputs on your surround sound system but not the Phono input unless the Phono input lists something aside from Phono, like Aux/Phono or CD/Phono.
Connect the S-Video or composite (yellow) video plug from your digital cable box directly to the S-Video or composite (yellow) video jack on your TV.
If your digital cable box does not have a S-Video (4 pins and flat rectangular hole) or Composite (yellow RCA jack) jack and only has the screw/push-on type cable with the pin in it, then leave the remaining connections as-is.
Now switch your surround sound system to the input you connected the red and white plugs to and turn on your TV. You should see picture from the TV, but hear audio from the surround sound system.
Apr 06, 2008 | Emerson EWF2004 20" TV
Please help me!!
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
Jan 25, 2008 | Philips HTS3440/37 System
Philips lx3600d
Common problem with the Philips - here is how to fix this issue:
-Tha Mp3 Doctor
Dec 20, 2007 | Philips LX3600D System
No surround sound for TV
-Tha Mp3 Doctor
Nov 18, 2007 | Philips HTS3400/37B System
Televison & Video Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
