Question about Cyclone Folding Treadmill
The machine keeps saying E02.It is a cyclone fitness factory treadmill
  • gfungafat May 22, 2011
    How would I know if the fuse is not good ???
  • gfungafat May 23, 2011
    Seems like the starting relay keeps going on and off
  • 776 Answers
There are only a few manufacturers of treadmills and they put a bunch of diffierent brand names on them. The E02 error is most likely a "no power to motor" error. Open it up and make sure the electical connectors to the motor are firmly attached. Hopefully this the problem and it is easily solved.
If it is more than just the wire attachement, it might be the fuse for the motor or, a bad motor control panel (this would be the most expensive option and likely not worth replacing. Look for a glass fuse (glass tube with metal on each end) and see if it is bad. The elevation motor might have a separate fuse so look for both.
Good luck
-Mark
Posted on May 22, 2011
  • Mark T
    Mark T May 23, 2011
    You should be able to look at the clear glass. There supposed to be a wire connecting the metal caps on each end of the glass tube. The wire will be melted or missing if Tripped. They are usually obvious when tripped. The wire will be fairly thick on one for this size motor and obvious that it is missing/melted. Make sure you get an exact replement.
Have a diamond t300+. Display screen is flashing E02 Some advice on what to do please?
This is a treadmill, dear, not a camera. If you want to get fit, why not go for a walk in the open air with your camera?
Feb 24, 2017 | Cameras
Error message E02 on Reebok ZR8 Threadmill - please help if possible
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 01, 2016 | Exercise & Fitness
When we star the treadmill E02 is apper
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error E2, Lift Error Probable Cause Error would occur if the incline is unable to move or if the incline position potentiometer is not functioning. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Troubleshoot as errors 40 and 42.
Precor Error Code E2
Oct 15, 2015 | Exercise & Fitness
I don't have users manual for pro fitness tread mill keep getting a fault saying E1
https://www.google.co.uk/search?q=Star+Trac+Pro+S+Treadmill+manual&ie=utf-8&oe=utf-8&gws_rd=cr&ei=-N_0VMutKufR7Qb_-IHgDw
youll find the manual
here is the service manual and maintance details you need to do
http://www.sportsmith.net/images/product_support%5Cstartrac%5CTechnical%20Manuals%5CTreadmills%5CSvcMan%20ProTread.pdf
Mar 02, 2015 | Startrac Fitness Products Star Trac Pro S...
How the error e02 on fit king treadmill be repaired
Dear sir,
I am having a treadmill of Fitking model no. W590 it is showing error code e02.
Kindly suggest what to do. I am eagerly waiting for ur response
Rgds
Yash Pal
Jul 15, 2013 | Exercise & Fitness
Sierra motorized treadmill with e2 code error
E02" You may not have enough voltage going to the machine. Turn the machine off and on
again at the switch at the rear of the treadmill. If this does not fix the problem you may have lower board problem see the diagrams attached and fix it.
God bless you2_4_2013_6_08_21_pm.jpg2_4_2013_6_09_23_pm.png2_4_2013_6_09_37_pm.gif
Feb 04, 2013 | Exercise & Fitness
Front rollerhas is rubber coated and the rubber has started to break up ,model is cyclone sx 9.0 max pro
This is a common problem with front roller that utilizes a coating that you described. Treadmill Doctor.com has these sleeves for icon fitness units they may work for your unit give them a shout they are in the state of Tennessee USA.
Aug 13, 2010 | Cyclone Folding Treadmill
Carl lewis treadmill
I also have this problem. I rang Carl Lewis Support and they said to check the connections on the circuit board (Located in the floor panel next to the motor). If the treadmill had recently been moved something may have been dislodged. I checked mine and found a few loose wires and plugged them fully back in but this didn't help my treadmill. I'm awaiting a response from an e-mail i sent them now.
Jul 06, 2009 | Exercise & Fitness
E02 Code
Faulty heating element, or main eprom is faulty
Jun 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Cyclone Folding Treadmill Logo
375 people viewed this question
Top Cyclone Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Cyclone Exercise and Fitnes Expert? Answer questions, earn points and help others
