Question about Cyclone Folding Treadmill
The machine keeps saying E002 - Cyclone Folding Treadmill
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
It says no data all the time
Please install Sonic Stage software in computer from Sony Support site then connect NW-E002 mp3 player with computer to transfer music files that will solve No Data problem.
Thanks.
Jun 15, 2011 | Sony NW-E002 MP3 Player
I have canon ir400 machine... it displayed error codes e002.. what i do? plz help me....
If the fuser assy has been repaired and you keep experiancing an E002 the problem is most likely a faulty DC Controller (main board) The DC Controller handles the voltage applied to the fuser assy and gives the error code E002 or E003. Have your tech clean & reseat connectors on the DC Controller before just replacing it. I have found cleaning the connectors & reseating them solves the problem 75% of the time.
Jan 12, 2011 | Canon imageRUNNER 400S Copier
E002 canon 6317
E002
1)due to fuser unit temperature control fault.
2)try to reset the machine by tuning on and off
3)fixing thermister or thermoswitch faulty due to cannot maintain fixing heater temp causes E002 appear.
4)check any paper roll over the surface of fixing roller.try to remove it.
5)fixing roller or fuser roller located near to printing output.
Jun 10, 2009 | Canon imageCLASS D761 Copier
Error code e002 on canon copier np6050
Also this code needs to be cleared in service mode. Despite what the display says, turning it off and on will not reset it. To enter service mode insert a straightened paper clip into the small hole in the front cover, near the meters, a "$" sign will appear on the display. Press * 4 * in order. Press ">>" to select "error" then press "OK" then power cycle.
(I cant remember on that model but you may need to defeat the interlock on the front door in order to enter service mode.)
Jun 02, 2008 | Canon NP 6551 Black and White Copier
Error code: E002 at canon NP6551
canon gp 405 copier their was problem E001 & E002 ?
I cannot find the problem
Canon NP-6035 persistent E002
e002 error normally indicates that the heater {fuser} is off
to clear that in most canon models there is a small press switch is to be activated to reset the error
at the rear right side of machine there is a small cover take it out and look for that small black button, press it while or immediately after switching the machine ON , switch OFF and ON again
if the error still exist may a real damage in fuser e.g. blown thermo fuse or lamp
Jan 25, 2008 | Office Equipment & Supplies
My mp3 player doesn't player
Use SonicStage to transfer music files. This can be downloaded fromthe internet.
Dec 05, 2007 | Sony NW-E002 MP3 Player
Cyclone Folding Treadmill Logo
Top Cyclone Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Cyclone Exercise and Fitnes Expert? Answer questions, earn points and help others
