Question about Gigabyte 8IG1000MK Motherboard
Continuous short beeping after RAM upgrade
I recently bought some ddr400 (pc3200) ram to upgrade my computer with. The cpu is currently a p4 2.66GHz 133MHz (533MHz) and my understanding was that the ram would run at a reduced speed to match the processor. I put the ram in a got the continuous beeping when the system is booted, so I checked the manual and found "continuous short beeps: Power error", so thinking my old 175W psu finally wasn't giving enough grunt for the new ram I replaced it with a 400W. Still beeping. So I overclocked the cpu to 200MHz (800MHz) ie a match for the ram and STILL beeping. Now I'm scratching my head. What is up with this motherboard?
  • ozwight Aug 17, 2008
    I've tried to old ram back in and it works, but this should be the right ram, it's ddr not ddr 2 or 3 and according to the manual for the m/b it is the right ram. There is a qualifier in the manual however that says "DDR 400 memory module is only supported when using FSB 800 Pentium 4 processer." That's why I cranked the cpu up to fsb 800 but It didn't solve the problem.
    Genius:
  • 1,400 Answers
No need to replace motherboard.The beep is an error code.
Try setting you bios to default or factory settings.Overclocking will in time cause a heat issue.
Use known to be good ram.Ive had ram bad right from the package.
If you want to go faster then consider a new mb and processor.
Posted on Jan 06, 2010
    New Friend:
I have the same problem with my PC. I could not solve the problem by changing RAM and PSU. Finaly I had to replace the MB with the new one. So this is the problem with the MB and The Motherboard should be changed. Please replace the MB with the new one.
-Tusar, Bangladesh
  • 781 Answers
Try the old ram back in if it works you have the wrong ram
ram comes in many shapes and flavours
ddr ddr2 etc
Posted on Aug 16, 2008
SOURCE:
I need to upgrade my pc ram, pulled the ram and infineon is the manufacturer, they no longer make ram so how do I know what other ram I can put in my motherboard, got number from stickers on the...
Look for labels on the RAM: PC100 or PC133 or DDR266 or DDR333 or DDR400 or PC2100 or PC2700 or PC3200.
Since you cited 'DDR400', you need to purchase 'DDR400' RAM.
Any sales-person in any computer-store can sell you 'DDR400' RAM.
Feb 03, 2011 | Abit NF7-S (V2.0) 400MHz FSB nVidia...
1.Suggest me the type of ram which is supported Foxconn 8657MF-series. 2.When i installs DDR400 RAM of 256MB it gives continuous beep(bee-bee-bee) sound. 3.What are the beep codes of Foxconn...
the beep sound on system starting before booting starts refers no RAM in system, if you need to upgrade your RAM then go for DDR-SDRAM PC3200 200MHz 512MB 0r 1GB.
Jan 24, 2011 | Foxconn (865G7MC-ES) Motherboard
I PLUG IN 2 NEW 512 MEM PCBS & WLL NOT BOOT. 1 BEEP FOLLOWED BY 3 BEEPS FOLLOWED BY 3 BEEPS FOLLOWED BY 1 BEEP. THEN NOTHING.
Remove the "new" RAM.
Look at the labels for PC2100 or PC2700 or PC3200,
or for DDR266 or DDR333 or DDR400.
Compare with the label on one of the "old" sticks of RAM.
Be sure that the labels on the "new" RAM are "equal" or "higher" than the labels on the "old" RAM.
For example, if the "old" RAM are DDR333, then you can use DDR400, but your computer will not accept DDR266.
Reinsert one of the sticks of the "old" RAM.
Does it still beep multiple times?
If not, then the new RAM is *NOT* compatible with your computer.
Jun 15, 2010 | E-Machines T1742 PC Desktop
What RAM to use. I would like to use 1600mhz RAM but am not sure what would be the best to use. I am installing 12gb of ram. I will install 6gb now and another 6gb later.
Memory  6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system memory (Note 1)
 Dual/3 channel memory architecture
 Support for DDR3 2100/1333/1066/800 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)
and
Memory support list Date Subject 2005/05/12 Recommended memory module list for GA-8I915P Duo Pro ...More 2005/03/01 Recommended memory module list for GA-K8VT800 (Rev 2.0) ...More 2005/02/21 Recommended memory module list for GA-K8NF-9 ...More 2004/12/13 Recommended memory module list for 8I845GE-RZ/C ...More 2004/10/15 Recommended memory module list for GA-8TRX330-L ...More 2004/09/02 Recommended memory module list for GA-8TRS350MT ...More 2004/03/22 DDR400 support list for FSB800 CPU support - GA-8IE2004P \ 8IE2004P-L ...More 2003/12/23 PC3200(DDR400) Recommended module list for GA-8TRS300M ...More 2003/11/28 DDR400 support list for FSB800 CPU support - GA-8PE800 \ 8PE800-L ...More 2003/10/16 Recommended DDR400 (PC3200), DDR434 and DDR466 memory modules for GA-SINXP1394 ...More 2003/10/02 Recommended DDR200/266/333/400/466 Memory support list for GA-K8NNXP ...More 2003/07/23 Recommended DDR333(PC2700) memory modules for GA-8S650GXM-P (-C) ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SQ800 Ultra and 8SQ800 ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SG800 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-8SG667 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-7VAXP Ultra, GA-7VAXP, GA-7VAX, and GA-7VA ...More
Dec 27, 2009 | Gigabyte GA-EX58-UD5 Motherboard
Is their a special make of memory card, ie: ddr
According to: http://www.shopping.com/xPF-VIA-MB-FOXCONN-VIA-KM400A-400M01-G-6L-R
this motherboard has 2 slots for DDR (184pin) RAM,
and supports a maximum of 1GB of RAM per slot.
Note that DDR RAM comes in 3 speeds: DDR266 (slowest), DDR333, and DDR400 (fastest).
Buy the fastest RAM -- if the motherboard cannot run the RAM at "full" speed, the RAM will automatically slow itself down to a speed that the motherboard will support.
Sep 15, 2009 | Foxconn 400M01-G-6L Motherboard
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
5 second beep/alarm
Hi krusty_623.
If this is new RAM, you might want to try removing the battery from the motherboard, resetting the CMOS (clears out all the old hardware settings) and putting the battery back in so that the motherboard redetects the RAM as if the setup was brand new. I've had the same problem only once on a RAM upgrade and it baffled me. Once I reset the CMOS the motherboard accepted the new RAM without any problems. I don't know if this will work for you, but it's a simple thing to try.
Spacetime
Oct 19, 2008 | Computers & Internet
Few questions about RAM memory?
Solution:
i)  LOW DENSITY modules have 100% compatiility with ALL systems and ALL chipsets.
    HIGH DENSITY modules only have 10% compatibility
    here compatablity means LOW DENSITY RAM are accepted by all system(100%)  or any make           system.. HIGH DENSITY RAM are accepted by 10% by only some system or computers...
ii) in order to check system performance or amount of Computer RAM usage press the ctrl+alt+del
   simultaneously a new window(window task manager) will appear showing:
    CPU usage: showing the amount of CPU or processor utilized at that particular time.
    PF usage: showing the amount of RAM memory utilized at that particular time.
    Physical Memory: showing Total RAM Memory, Available Ram memory....
iii) baiscally they are two types of RAM they are:
    DDR1:which is older one supported by older system  or older mother boards which is costlier
    DDR2: which is latest one supported by all new system or new mother boards which is less                         costlier
    DDR: double data rated ram......which will send data at a double rate compared to SD RAM
iii) here color doesnt matter, these slots either support DDR1 or DDR2 but not both at a time
    DDR1 has 184 pins or gold plated pinssss... on the edge of the RAM
    DDR2 has 240 pins
    so difference doesnot allow DDR2 to placed in DDR1 motherboards or vice versa...
iv) it does have anything to do with no of chips on the RAM but they only differ whether it is DDR1 OR DDR 2(DDR2 are much faster than DDR1)
NOTE: whatever may the the RAM, each RAM has FSB(called Frequency...) which determines the frequency of rate at which data is tranferred from RAM to processor(CPU)  usually in MHZ such as FSB 300, 400, 200 , 333...................
more the FSB the faster data is transferred to the processor(CPU)
dont worry even RAM with less FSB's work well with the processor....having 1 GB RAM or 2 GB RAM is engouh, it only matters with the speed of CPU ... but not RAM......
Sep 24, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Asus a7n8x MB and ram
i just checked & yes you can from what i was reading
Mar 30, 2008 | ASUS EN8500GT HTD DDR II, PCI Express...
Open Questions:
See all Gigabyte 8IG1000MK Motherboard Questions
Gigabyte 8IG1000MK Motherboard Logo
900 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
