SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either + or – to turn On or Off.
3. Press the PTT to confirm or MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
SOURCE: binatone MR 250 walkie talkie is locked how do i unlock it?
Try holding down the ENTER button
SOURCE: New walkie talkies wont stay charged and wont
It's really hard to tell what's going on without more information, but it sounds like your two problems are really one; that is, the shutdown is due to low battery power. If you have a voltmeter you can check the charger output and the battery voltage when fully charged. My bet is that the batteries are no good, so they are not taking a full charge and are discharging rapidly. Try new batteries in one of the radios and see if that solves the problem.
SOURCE: walkie talkie symbol stuck on cannot remove it
The symbol you are describing indicates you have the radio on HI power. It will not go away unless you reprogram the radio to LOW power, or change to a low power channel. Here is a link to the user guide: http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNiD%20Manual%20EN.pdf?localeId=252
Best regards.
