Question about Hunter Low Profile III 20807 Ceiling Fan
Hunter Ceiling Fan with Remote - changes speed on its own
Just installed a Hunter Ceiling Fan with a remote. The fan will change speed on its own with out touching the remote. Actually saw it happen last night. I was not using any other appliance/remote at the time.
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
SOURCE: Hunter 3 speed ceiling fan now turns slowly
Probably a bad capacitor. What model is it? If it completely wireless (in other words: no pull chains for light or fan) the capacitor is located on the receiver for the fan (in the canopy or the lower switch housing). Unless you are handy with a soldering iron, it is easier to purchase a replacement receiver.
Posted on Jun 18, 2009
  • 7 Answers
SOURCE: Hunter ceiling fan is stuck on high speed
If it has a chain, buy a light dimmer switch so it will not have 1 speed anymore. If it has a remote control, buy a new remote control like your old one. Try different numbers on remote control.
Posted on Jun 27, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
  • 34 Answers
SOURCE: HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Posted on Sep 10, 2009
I have a Hunter ceiling fan with a remote control model number 85095. The remote will turn the fan on and off and change the speeds but it will not turn the light on or off anymore. Any help?
Make sure the wires to the light kit are connected to the light & light wire connected in ceiling.If that's not your problem then you probably need a new receiver. Call 1-888-830-1326 and have your FAN model handy.Should be a five digit number beginning with a 2.
Jan 14, 2013 | Hunter Ceiling Fan Remote Transmitter...
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
I just installed a hunter ceiling fan with light & remote control but the fan will not shut off or change speeds
Sorry for this::::You may not have the correct remote for the fan.
The fans are difficult to install.
Kudos to you,Sir.
Nov 13, 2012 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
I just installed a 52"
yes this is because the dimer is giving the light less power.you just need to change the switch to a single switch then your dimer will work right all the time. good luck
Aug 12, 2011 | Hunter 52" Ceiling Fan With Light And...
Need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Apr 24, 2010 | Hunter Ceiling Fan Light Remote Control
Wacky remotes
change the frequency on both so they are not the same they have to be changed in the fan transmitter and receiver
Jul 30, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Remote controlled ceiling fan has mind of it's own.
I have the same fan. The fan and the remote have some "jumpers" which allow you to change the codes, useful if someone else nearby has the same fan. You can see the jumpers inside the remote, open the back cover... you'll see "4 3 2 1" on the circuit board. Unfortunately you'll need to dismount the fan to change its jumpers, they need to be the same as the jumpers in your remote (which you can move around pretty easily).
Jul 01, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Apr 01, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter Low Profile III 20807 Ceiling Fan Logo
467 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
