Question about Corel Ulead DVD MovieFactory 6 for PC
I have a problem of 0xc000005a error that appears in Ulead movie factory6 forbiding me to use the program. need help!!
No capture driver in ulead DVD movie factory 6
Repair the program by going to Control Panel --> Add Remove Programs --> Ulead MF6 --> Change/Remove --> Repair.
You must have the original instal disk in you optical drive for this to work. This solved the no capture driver error message for me. If this doesn't work I would uninstall and reinstall the whole program.
Sep 09, 2010 | Ulead DVD MovieFactory for PC
Program shuts down during the burn process.
reinstall the program again and make sure your drivers are properly working
Dec 02, 2009 | Ulead DVD MovieFactory for PC
Ulead movie factory 6.o I cannot overcome a relink message any ideas please
Do you have the Ulead program on disk?
Go to Start>Control Panel>Add/Remove Programs, and remove Ulead. If asked to restart your computer, do so. If not, close all windows until you are back to your desktop scree, and restart your computer. (Windows XP: Start>Turn Off Computer>Restart)
After Windows boots back up again, and all your Start Menu programs, reinstall Ulead again.
Nov 03, 2009 | Computers & Internet
Problems running Ulead 6.0
can you tell me the activation code please
Jan 25, 2009 | Ulead DVD MovieFactory for PC
Where can i find Movie editing software?
ulead video studio is the best solution for you. to know more about ulead video studio click on the www.ulead.com link
VISIT ULEAD WEBSITE
DOWNLOAD ULEAD VIDEO STUDIO X2
use deamon tools to mount the file.
Jan 22, 2009 | Computers & Internet
New vista lap top....using my VIDEO STUDIO 8 program
no, this is not, u need to learn the application by user manual or any other help, otherwise use some other application like adobe primeir etc.
Nov 17, 2008 | Ulead Videostudio 8 for PC
No sound
try yo use ulead movie maker, nero movie maker or windows movie maker. i really prefer to use ulead its my choice of uploading editing and saving. hope that helps!
CHARCOIS
dont forget to rate my post. thanks!
Aug 03, 2008 | Sony Handycam DCR-TRV140 Digital Camcorder
Ulead dvd workshop 2
You can install and run a Ulead software for Windows XP on Windows Vista by running
the Program Compatibility Wizard. We do not guarantee full stability for Windows Vista though.
To run Program Compatibility Wizard:
1. Open the "Program Compatibility Wizard" by
clicking the [Start] button, clicking [Control Panel], clicking [Programs],
and then clicking "Use an older program with this version of Windows".
2. Click [Next] when the "Program Compatibility Wizard" dialog box comes up.
3. Select "I want to use the program in the CD-ROM drive" and click [Next].
If the installer is not detected from the CD-ROM drive, please manually browse for the installer executable.
4. Under "Select a compatibility mode for the program" step, please click on "Microsoft Windows XP (SP2)" and click [Next].
5. For the display settings, please click on "Disable Visual Themes" and "Disable desktop composition" then click [Next].
6. Click on "Run this program as an administrator" and click [Next].
7. Click [Next] to start testing the compatibility settings.
This will launch the installer so if you have your firewall enabled, it will prompt for a permission request.
Please grant permission for the setup to continue. 8. The setup will now run.
You can allow it to finish or switch back to the "Program Compatibility Wizard" dialog box.
9. It will ask you if the program ran correctly. Click "Yes..." if no other pop-ups appear.
* Try another compatibility setting if it reports a problem with the display. For the display settings,
enable the option "Disable display scaling on high DPI settings" as well.
10. For this next step click "Yes" to send the info to Microsoft and finish the process.
* Now that you have the software installed, you will also have to run the "Program Compatibility Wizard"
for the application to run correctly. Use the same procedure except for step [3],
select "I want to choose from a list of programs". Follow the same procedure for the other steps until you finish the setup.
Nov 16, 2007 | Ulead DVD Workshop 2 for PC
Windows Movie Maker to Ulead DVD Movie Factory 6
Ulead Movie Factory Requires you to Create a "Menu" First,or else it will Loop over and over again.
Oct 20, 2007 | Ulead DVD MovieFactory for PC
Corel Ulead DVD MovieFactory 6 for PC Logo
104 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
