At first it had no heaters, which i fixed. now it has a vertical line (vertical collapse
    Genius:
  • 1,112 Answers
Hi:
you did not mention what type of television but from your complaint i am assuming its a Crt or Crt rear projection, In which case check the vertical IC for deftects and replace also check the capacitors in the vertical section of the deflection board, next check to make sure the vertical IC has B+ going to it, this voltage is usually taped from the Flyback transformer.
Posted on May 22, 2011
Cause of vertical collapse on glendale tv chassis
collapse means just a white line left to right in middle of screen--usually a bad solder connection at the vertical output chip or a bad part in that area.
Nov 07, 2012 | Televison & Video
Vertical collapse on glendale chassis
I tried to fix my tv and accidentally hit v- something (last page of service menu). Now There is a horizontal green line in the middle of the screen. How Can i fix it?
V stands for vertical output. You have a vertical collapse. Go back to service menu, and set range for vertical. Or you can try factory reset.
Nov 24, 2011 | Apex Digital AT2708 27" TV
Horizontal line across screen
HELLO
This is called "Field Collapse". Line collapse is different (a single vertical line) in the centre of the screen.
But field collapse is usually a fault in the field circuit (possibly a field output IC has gone short circuit) or electrolytic capacitors have dried out. The same can happen in a CRT TV - looks as if LCD panels are the same way! I think you will have to take this to a service centre.
GOOD LUCK! (:-)
Sep 12, 2009 | Memorex Televison & Video
Picture appears only as a thin, horizontal line...
chk vertical amp /vertical drive i/p from oscillator/power to it/power to vertical amp/chk dry joints-hot area/look at vertcal amp capacitors-swelling etc
Jul 04, 2009 | Akai Televison & Video
Sony Bravia 46Z4100 has a thin vertical red line on the screen
I assume that when you get the line you lose the picture, if so, you have vertical collapse, either a dry joint in the vertical section or capacitors or vertical I.C., I would doubt that the scan coil would be O/C as that is rare. if you can't do it yourself I suggest taking it to a repairer, as it should be an easy fix...Hope that helps...Phil
May 19, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Vertical amplifier?
Your right, it's called "Vertical Collapse", it's caused by the vertical output IC, which may be dry jointed or failed, try applying new solder to it if you can, if that does not work, you will need to replace the IC. A simple test to test for dry joints (where the solder is cracking and not causing proper connection from the pins to the board). If you give the unit a bit of a hit you may see the picture return to normal... don't do this too often as you can make more damage.
May 05, 2009 | Televison & Video
Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Apr 22, 2009 | Televison & Video
Bright line coming in center of screen
Hi Shailendrar , your problem sounds like vertical collapse , the whole picture has collapsed into a thin , very bright centre line ? maybe the result of dry solder joints , does banging on the side of the tv temporarily fix ? if so , the circuit board requires inspection for bad solder joints . Alternately the vertical chip/transistor may be blown , replace as required. Cheers T
Dec 05, 2007 | Philips 19PR19 19" TV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
