I just recently got directv installed and ever since my volume on my sansui tv turn down by itself any idea why
    Genius:
  • 1,112 Answers
Hi:
Most cable or satelite boxs have their own volume controls try using the boxs remote to change vol levels to see it this solves your problem.
Posted on May 22, 2011
My sansui LCD TV won't turn on or do I have volume any ideas to fix it
What do I check if my Sansui TV Model SLED2490 will not ...
https://www.ifixit.com/.../What+do+I+check+if+my+Sansui+TV+M...
iFixitJul 9, 2014 - A friend of mine gave me a Sansui TV after a power surge caused ... led ·sansui · tv power ... The most common problem that I've researched and experienced with your tv's is that when they get unplugged, the wont turn on, just stay in ... though they'll still be frustrated, they won't trash their tv and go get a ...
I have a sansui tv and it wont turn on but is getting power ...
Nov 28, 2015 | Sansui Televison & Video
Trying to get my directv remote to control this TV but none of the Sylvania codes recommended work any ideas
slide the mode switch to tv, hold down mute and select until the light blinks enter "9-9-1-------1" when the lights finish blinking start pushing push the channel up button. this is a code search. It will transmit every code it knows one at a time. when the tv turns off you've found a code that works. turn it back on, try the volume and see if it works correctly. when finished press select.
most tv/dvd and/or vcr combos won't work with tv codes.
Directv has posted many new codes on their website for combo tv's Go to [ www.directv.com/remote ]to look up the latest codes read the programming section for the remote as there are many customizable features on the remote that most people aren't aware of. good luck
Sep 23, 2009 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Directv remote : need sansui code for tv/dvd combo
Heyo, gotta love 18 year olds like myself, we fix everything :P Seriously though, after searching for awhile, I wen't here and found it (for an rc64 at least). Go to this link and go under tv codes and it has like 5 new codes not listed anywhere else. http://images10.newegg.com/User-Manual/User_Manual_80-150-003.pdf
Aug 21, 2009 | Televison & Video
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
May 10, 2009 | Sansui HDLCD3210 32 in. LCD TV
Sansui 13" DTV1300 shuts itself off
My girlfriend had the same issue with her 1300a. We saw on another forum that they took off the extra AV panel and infared receiver, so we opened it up. We couldn't really find either, but when we tightened all the plugs up things seem to be working fine again. Back to watching the Lifetime channel :(
Mar 18, 2009 | Sansui DTV1300 TV
I recently hooked up my dtv box, tuned the antenna and have a great picture. On every channel I have background noise. Sounds like bacon frying, hissing noise. I also set up someone else's tv, very simple....
If there is a volume control on the remote that came with the converter box, use it to make sure the box volume is set to its maximum. Many models allow you to control the volume out from the box to the TV, and the levels are set about halfway. When you turn up the volume on the TV cause it's too low, you can get the kind of audio problem you describe. Make sure you turn the volume down on the TV first before starting with the box.
Feb 18, 2009 | Directv (R10) DTV Receiver / 70-Hours...
CODE FOR DIRECTV REMOTE
I am a installer for Directv and tv's that incorporate a dvd and/or vcr usually do not respond to the directv remote. Trust me I tried all the codes. I did find programming the av1 on the dtv remote for the dvd player would control the volume and on/off for the tv. Try the dvd codes rather than the tv codes. If no luck I recommend a Harmony remote which works well with combo tvs. Although expensive they are you must consider the convenience factor they provide.
Aug 27, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Low volume on playback
The volume control on the TV does not affect the recording. However, if you were recording from a set top box, and you turned the volume down on the box and not the TV, then this would cause the problem you describe.
If this is the case, then try to keep the STB volume at maximum and only use the TV volume control.
Also, some DVD players and VCRs have a lower output than the standard TV tuner, so an increase in volume is usually needed.
You might want to try some test recordings to see what happens.
May 08, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
HELP ME PLEASE.............
Make sure Closed-Caption is turned off.
Turn set on.
Set Volume to Minimum.
Press both Volume down on the set, and #0 button on the remote.
V-Chip password should now be released.
Bill
Mar 31, 2008 | Sansui H TV2600 TV
Programming the directv remote to program a sony audio receiver
Go through the process of setting up the remote again instead of trying the volume first use the power off button. In my experience, Sony receivers can be picky and power cycling "will" insure the code set, then try the volume.
Nov 03, 2006 | Directv HR10-250 DTV Receiver
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
