Radio code for phillips sc201(c)
Can you help with a code for the phillips sc201,has a card with it which has the code of 1059,but this does not work, the serial number is;GM0201P1065078,thank you,Tina
  • 2,071 Answers
SOURCE:
Corsa. Replaced battery. What is the code to restore radio operation?
start the car then remove all battery replace new one
Aug 07, 2015 | Vauxhall Cars & Trucks
Radio code for philips sc201 in vauxhaal corsa
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
Aug 24, 2010 | Philips Car Audio & Video
Need code for m reg astra its a phillips sc201 reg plate is m482twu
The radio will have to be removed from the car  dashboard .
Then please quote  ALL the LETTERS and NUMBERS  on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Mar 05, 2010 | Philips Car Audio & Video
I need a radio code for a vauxhall corsa
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here  for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST A NEW  QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
note: Unfortunately not all radios can be decoded using the Serial Number
Otherwise try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Nov 19, 2009 | Car Audio & Video
My Ricoh printer is flashing error code SC230
Looks like the laser unit has quit!
SC230
V-Sync error
Subscan signals are not
asserted.
See SC201.
SC201
Polygon motor error
After the main switch turns
on, the polygon motor is not
phase-locked in several
seconds.
• Incorrect cable connection
• Defective engine control board
1. Connect the cable correctly.
2. Replace the engine control board.
3. Replace the laser scanning unit.
4. Check or replace the cable.
Oct 26, 2009 | Ricoh Aficio CL2000N Laser Printer
Need to unlock my sc201 phillips car stereo. Battery gone flat and now stereo in ''safe'' mode. Serial number is gm0201p9478751
i have a philips car stereo with 1 -5 buttons tape player in my 1991 ford falcon original want to no the buttons i press to be able to put the code in
May 07, 2009 | Philips Car Audio & Video
446 people viewed this question
Ekse
 Grubhead
Grubhead
