I want to hook a motoral cable box to a phillips tv and a admiral vcr and a sony receiver to get the best surrond sound from the system
  • 2 more comments
  • kensteidl May 22, 2011
    ok hold on i will get them for you thanks for repling to me
    ok the vcr model # is JSJ20433 the receiver is HDC-HDX589W cable box is DCT5100/1005 and the tv is 42PF5321D/37 42P
    yes the model is JSJ20443 and made by gem star corp
    ok the receiver is made by dolby labs
  • 8,197 Answers
May I get the model # of all the units to help you more
Posted on May 22, 2011
  • 2 more comments
  • Jyackle5
    Jyackle5 May 22, 2011
    I will be here when you have
  • Jyackle5
    May I ask who makes the reciver. Also can you double check the model #
  • Jyackle5
    You might want to look at the link below page 25 or 3-2 to page 32 or 3-9. You will want to look at page 27 to 29. on the link below.
    http://www.sectv.com/WB/PDF/DCT5100.pdf
  • Jyackle5
    Please look at the link I gave you it will tell you how to hook up
I just purchased a Sony flat screen tv and need advice on what wires I need to connect my Denon AVR-3300 to it or to the dish cable box? My remote has these options on the remote to listen in...
Your reciever has three digital optical inputs so, what it comes down to is how many thing do you want to hook up and what input/otput do you have on your TV. Best case scenario would be to hook your cable box directly to your TV Via HDMI out, if you have HD, on your cable box to Sat/cable input on your TV. Next best would be using componenet cables for video and digital optical for audio. Last would be RCA(yellow, white and red, from Cable box to TV input. Then, you would connect your TV to receiver via(best) digital optical, or RCA. You can try to patch the video through the reciever using component or RCA to TV/DBS on receiver then out to TV but. alot of times you will lose the video in the transfer and it uses more cables, thus more margiin for error. You would set your TV menu to cable/sat and your reciever to which ever input you choose.
Jul 03, 2011 | Denon Audio Players & Recorders
Bought new samsung dvd/vcr. have an older admiral tv with just a cable hole. this is the second tv on a dish network, so this tv only has a cable, the box is in the living room. so how do I hook this...
The easiest way to make it work is to:
1- run your cable into your new VCR to CATV IN.
2-Your VCR should have come with a short length of cable. Connect it from the OUT jack to the TV.
3- Set the TV to either channel 3 or 4- you need to check the VCR manual to see which channel you have to use. Some VCR's have a small switch labeled "channel select"- if so, set it and your TV to the same channel... your choice.
4- Leave your TV on the channel you set above all the time. You will now change your channels using your VCR. You will be able to record whatever you are watching.
Feb 12, 2011 | Televison & Video
Can't find where to hook up tv coax.
As far as I can tell your TV is just a monitor. You would have to buy a separate tuner. I had the same problem with mine and found it was cheaper just to use an old VCR. I hooked up the coax wire up to the VCR and hooked the VCR to my TV with composite cables and changed my channel through the VCR. That will only work now if you're using cable because of the switch to digital. If you're using an antenna you will need a digital tuner.
Aug 08, 2010 | Philips 32FD9954 32 in. HD-Ready Plasma...
Ps3 is hooked in to the tv with hdmi cable but sound will not play through the surrond sound system
you need to find the audio out for the tv and run the sound from the tv to the sound system.
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
AUDIO
This TV ONLY transfer audio OUT to a ANALOG SYSTEM THRU AND ANALOG SIGNAL. That is, TV will play sound fine in your surround system but any digital (HDMI) wont sound.
Mar 11, 2008 | JVC HD-56FN97 56" Television
Connecting receiver/dvd and vcr combo and TV
do u have rca outs form the tv to the aux in of any dvd system sterio unit
Jan 10, 2008 | Sony DAV-FC8 System
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
