Question about Fujitsu LIFEBOOK NH570 - Core i7 620M .66 GHz - 18.4in. TFT (S7858653) PC Notebook
Hello. My Fujitsu LIfebook NH570-F3 notebook shuts down when i connect an external usb hard disk (LACIE 1T 2,5" without external power) to any usb port. The same happens when i connect any other smaller disk. It also shuts down when a cd/DVD is inserted in the Blueray/DVD player and therefore i cannot even run the original RESCUE DVD. Also when I connect a flash memory it says that the device can perform faster if connected to a USB 2.0 port. It seems that the driver has changed to usb 1.1? Please help. Thank you in advance. Takis
pankaj_dic
  • 1250 Answers
SOURCE: USB not functioning
hey your all usb ports are not working or a single port thats giving the problem
Posted on Nov 09, 2008
hokuwho
  • 306 Answers
SOURCE: win 2000 on fujitsu siemens lifebook b-series
  • Boot to the xp cd
  • After the setup installs then it will ask if you want to install xp, repair or install to another partition.
  • Choose install and the install program will say that it is inspecting and looking for previous Windows.
  • The dialogue will now say that a previous Windows is installed and to choose whether you wish to install on the same partition -you do not, delete that partition -you do. I think it is "D" to delete, then "L" on the next Window.
  • When you see the next screen it will list the partitions. Notice the "unpartitioned" disk space -that is where you want to install the new Windows.
  • It should be all or most of your hard drive space. If there are other partitions delete those as well unless there is a relatively small partition, say 4 or 8 gigabytes partition that may have information stored for the hard drive itself to use for it's own purposes.
  • When you have the unpartitioned space maximized by deleting the existing Windows you be asked if you want to format the drive in NTFS, Fat32 or leave intact or quick format.
  • Choose NTFS, full format (slow) and let the format begin.
  • When complete it will reboot automatically or you can reboot yourself.
  • After reboot the Windows driver load and inspection will repeat but this time you will have a formatted partition. Choose that for your new install of Windows. After that is complete reboot to your hard drive, not the cd. You can remove the cd if you want to make sure you are booting to the hard drive but the new Windows installation may ask that you reinsert the cd as it loads drivers and so on. At this point have any other cds available for installing drivers for printers, video cards, network adaptors and so on. If you do not have them then download the Windows 2000 drivers to a thumb drive or cd before you do this install.
  • Windows has program compatibility program that inspects or lists what devices might not be compatible with Windows 2000. Also the manufacturer can tell you what Windows versions they can support. Here is a comprehensive list of Microsoft downloads for Windows 2000. Make sure that you have service pack 4 downloaded to cd or thumbdrive.
  • http://www.microsoft.com/downloads/results.aspx?pocId=38DF6AB1-13D4-409C-966D-CBE61F040027&freetext=2000&DisplayLang=en
  • Take you time and let me know if there are any problems encountered. I am certified for Windows 2000 Pro OS and networking. ~Steve Medley
Posted on Nov 10, 2008
  • 159 Answers
SOURCE: I HAVE A PROBLEM W/ MY FUJITSU LIFEBOOK FMV 6866NU
You can download new drivers from here:
http://www.falconfly.de/voodoo2.htm
That's a spectacularly old laptop, fyi. The video card manufacturer went out of business a decade ago.
Posted on Dec 07, 2008
Geekman
  • 32281 Answers
SOURCE: Fujitsu Lifebook C4135 specs (32bit CardBus slot included?)
This is a very old laptop, when new it was installed with Windows 98.
Not sure if it had a PCMCIA slot on the laptop, but it can be easily identified if you look on the laptop. If it has PCMCIA slots, most likely it would be located on the LHS or RHS of the laptop. The PCMCIA could be a single slot or a double slot and it would be 55mm wide ie 2 3/4 inches wide with an eject button for a single slot and two eject buttons for a double slot.
Posted on Jul 06, 2009
  • 59 Answers
SOURCE: touchpad stopped working on my Fujitsu lifebook
You need to re-enable it. Hold Fn and hit the F5 or whatever key is appropriately assigned to the touchpad. This should enable it for you.
Posted on Oct 19, 2009
Black screen one light on and the fan makes at noise
Try an external screen and see if the laptop boots successfully into windows.
Jan 08, 2013 | Fujitsu LIFEBOOK NH570 - Core i7 620M .66...
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
When turned on (either with battery only or with both battery and utility power connected) the laptop displays nothing except a blend of colored vertical lines. And, it doesn't seem to power up at all,...
Hello
Plug in an external monitor. If the external displays fine, then the video card is also fine. Gently pinch the edges of the LCD screen where the lines terminate. If the lines change or go away, then it needs a new LCD screen.
Good Luck,
Dec 22, 2010 | Fujitsu 16'' LifeBook N7010 Laptop PC w/...
I have a Lacie 160GB external HD that seems to have power supply issues. When I plug it in an turn it on, the blue light comes on and "shimmers" - it's not a full glow, but it's not a flicker...
The Lacie has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 07, 2010 | LaCie (300740) 160 GB Hard Drive
My Lacie 1T hard drive tells me it has insufficien memory when I try to add a file it is brand new how do I reformat it?
Have you followed the steps given below accurately ? If not, do it once again please
1. Connect the power supply.
2. Connect the USB, FireWire or eSATA cable to your computer and to the drive.
3. Turn on the drive by moving the power switch to On or Auto (drive powers on/hibernates automatically). The drive will mount in My Computer (Windows) or on your desktop (Mac).
4. Before using the drive, LaCie Setup Assistant software must be launched to format your drive. It will
• Optimize your drive according toyour needs
• Copy the manual and utilities on
your drive
I Hope this is helpful
Nov 03, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Want to use clone hard drive to run XP
Because the HP and Fujitsu have different devices, you cannot clone (or create an image of) the hard disk and expect it to work on the other laptop.
Your best bet would be to copy your data files onto a USB memory stick or an external USB hard drive and plug it into the HP. You can open the files on the USB memory Stick/hard drive to work on them or copy them to the HP's hard drive to work on them.
When your Fujitsu has been repaired you can copy the latest files from the USB memory stick/hard drive back onto your Fujitsu.
Jun 19, 2009 | Fujitsu LifeBook S7010D Notebook
Fujitsu LIFEBOOK NH570 - Core i7 620M .66 GHz - 18.4in. TFT (S7858653) PC Notebook Logo
76 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
