Question about Garden
We do not know how to take the snow plow off of our john deepe L100 tractor. We removed cotter pins from the bolts, but now we do not know how to remove the bolts. they are stuck in place. Do we unscrew them or do we hammer them out? we can't figure it out. can you help?
    President:
  • 3,074 Answers
Gently tap them out, Tim
Posted on May 22, 2011
How much weight do you need on a John Deer 105 riding tractor with a front snow blower.
snow blower, why do you need any weight? You are not pushing snow you are running up to it and having it blown away.
Having said that, I use Rear chains and 100lbs of weight to PLOW with my Garden tractor
Dec 10, 2017 | Garden
The steering cylinder is leaking on my John Deere F710 mower. Can this cylinder be rebuilt ? And how do I remove it?
To remove there pins on each end, removed cotter pins.
Your seal is leaking. You can replace the seal youself or take it a hyd. shop.
Aug 26, 2015 | John Deere Garden
How to install. A snow plow and ordering a couple of parts for it
From the part numbers you post I gather it is a John Deere equipment and your local JD dealer will be your best bet getting instructions and parts for that snow plow.
Jan 01, 2015 | Garden
Snow blower auger stops in snow
There are cotter pins on the second stage blower shaft. I would inspect these. Also, check sheer pins in front auger assembly.
Dec 03, 2013 | Garden
What hold the steering column to the john deer perego tractor and makes it turn
usually a washer and a cotter pin, or a nut and bolt at the steering wheel
Aug 27, 2012 | Peg Perego John Deere Farm Tractor and...
Craftsman 42'' mower when clutch-brake is engaged and released...the level does not return to original position which prevents mower from running at selected speed. my manual does not provide diagram of...
Seems that your clutch needs adjustment, no biggie here. Get your needle nose pliers and a spare ¼ inch bolt or pin. A small Philips screwdriver will also work. The needle nose pliers are for removing the cotter pin and the screwdriver (or bolt) will hold the brake lever in place while you make the adjustment. Then, check under the right side of the deck (side where the grass discharges) right under the plastic mat where your foot rests and next to the tractor's frame you will see the brake lever with the long spring attached. Have a helper move the brake/clutch pedal so you have a better idea of what's going on down there. Then:
1. Remove the cotter pin, washer, and brake spring from the
adjustable nut
2. Disconnect the adjustable nut from the brake lever assembly
and the parking brake latch.
3. Align the hole in the brake lever with the hole in the frame. Hold
the brake lever in place with your 1/4 inch pin, bolt or the screwdriver.
4. Pull the clutch rod forward until tight. Turn the adjustable nut
until the nut will fit through the hole in the brake lever.
5. Assemble the adjustable nut to the parking brake latch,
brake lever and brake spring. Fasten with the washer and
cotter pin.
6. Remove the 1/4 inch (6 mm) pin, bolt or scredriver.
That should return everything to normal. Assuming that there are no broken or bent parts in your clutch mechanism.
I hope you find this solution helpful. Please rate it and thanks for using Fixya. Good luck!
Sep 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Aug 22, 2009 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
