Question about Prestige Remote Start
My prestige remote car starter is not working, my husbands is, mine is slightly different with the longer range, but they both look similar. They are Model APS-921
3 Suggested Answers
  • 13 Answers
SOURCE: prestige aps-57 remote start...car won't start
Hello hope this can help you. First check the starter wire, it is tan/lt blue located at the ignition harness. usualy during installation of the remote start system this wire is cut leaving you with two ends. one wire is coming from the ignition switch the other is going to the starter. the brain of the alarm hooks into both of these wires. if the repair man cut the wires from the brain and spliced them together he has just put the system back to OEM status leaving the alarm no way to engage the starter. I believe that may be where the problem lies but if not then I would say check your immobilizer bypass module the repair man mave have diconected that.
Thank you,
Luis
Posted on Dec 04, 2008
  • 152 Answers
SOURCE: Reconnect remote starter
Those devices, when operating properly, are commonly not disconnected, but you could attempt to find the power lead and the in-line fuse to make those re-connections, also check the battery(s) in the remote. If the disconnection is more in-depth then you should acquire the installation and owners manual from Audiovox, so as to troubleshoot and maybe discover what else is disconnected.
Good luck...
Posted on Feb 23, 2009
My remote starter quit working. I replaced the battery but it still will not work. How can I tell if it is the remote? How can iI troubleshoot it?
This is most likely the key that is on your window. the contact may have come loose or slightly out of alignment. Try that first then take it back to the installer. I am sure they will get it working again without a fee.
Jul 02, 2014 | Prestige Remote Start
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
My preinstalled prestige remote starter has worked twice at the dealers and i got it to work once. my question is do this combination sounds fimiliar for a chevy 1500. lock doors...lock door again, ho
If it is an add on remote starter, then you would use the factory remote to start it. If using the factory remote to start there are a couple of combinations to start it. Try lock, unlock,lock for Prestige/Pursuit models. If Directed models, try lock, lock or lock, lock, lock. If its a GM remote starter, press lock and then hold the remote starter button(circle with arrow.
Aug 03, 2012 | Prestige Appliances Vehicle Parts &...
I have a new prestige car remote installed recently and i have a problem how to shut off the alarm coz the installer did not or forgot to give me the manual. When i start the car remotely i press the...
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Jan 23, 2011 | Prestige Remote Start
Prestige remote starter fell in bowl of water
Wasn't the unit hooked up already? You can't plug it back in? I'm still trying o picture the dropping into a BOWL? of water???
Give me the model and I can give you color codes, but if the wiring is still in tact you shouldn't need to rewire. Let me know and I'll help you out.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 28, 2009 | Prestige APS686T Remote Start and Keyless...
Do these work with pus button ignitio
Yes, the remote start can still operate your car, but I suggest not installing it yourself.. Take it to a reputable shop in your area! Push button start cars are different than regular key ignitions, so if you have no experience with remote starts, dont try it.
Dec 11, 2008 | Prestige Remote Start
2006 Chevy Impala Remote Start Poor Range
Yes some do some don't, my 2005 Dodge 200-400 feet, my 1996 Corvette 20 feet, my wife's 1998 Buick about 50 feet, is the remote battery ok? should be changed at least once a year
Dec 03, 2008 | 2008 Chevrolet Impala
Prestige aps-57 remote start...car won't start
Thank you,
Luis
Dec 01, 2008 | Prestige Remote Start
Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
Prestige Remote Start Logo
199 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
