Question about Yamaha RX-V396 Receiver
Want to know if it is possible to hear a record player through the AUX plug out? since my Yamaha RX-V396 receiver doesn't have a phono plug out
  • Yamaha Master
  • 6,694 Answers
Only you can hear the record player through the aux of your amp if the record player comes with built in phono preamp. If not you need a phono preamp between the record player and amp or an amp which have a phono input. Phono preamp is available in the open market.
ok
Posted on May 22, 2011
How do I connect my Yamaha RX-V733 to cd player?
Assuming the CD player has a standard 3.5mm headphone jack, get a 3.5mm to RCA audio connector. Put the 3.5mm plug into the headphone jack at the back of your CD player (or audio out if that's what it's labeled) and attach the white end of the RCA jack to the white connector in the Phono at the back of your Yamaha RX-V33 and the red end to the red RCA connector just below it in the same Phono area.
Switch the Yamaha to "Phono" and start the CD player. You should hear things now.
Feb 21, 2017 | Yamaha Audio Players & Recorders
Can you connect a turntable to a denon receiver with no phono input?
Buy an external phono pre-amp and connect it to the AUX inputs on the back of the receiver.
May 25, 2014 | Yamaha RX-496 Receiver
Low volume from my thorens td-145 record player
Have you checked the cartridge in the turntable arm?Also check to make sure receiver/tuner is switched to Phono or Aux..Also check to see if there is a speaker switch on receiver.
Mar 07, 2010 | Thorens TD-170 Turntable
How do i hook up an ipod to the rx v596
If you get a dock and a 3.5mm plug to two RCA phono plugs lead, it will then connect to any spare aux imput socket. At the same time the dock will keep the battery in the i-pod charged. Or you can just plug the same lead into the headphone output of the i-pod, but the battery will run down.
Feb 28, 2010 | Yamaha RX-V596 Receiver
I have not been able to record LP's. The instructions mention hooking up the cables to the receiver outputs down to the TDK deck. Which outputs? Tape, Aux,? I tried splitting off of my phono outputs with...
your phono outputs are a whole diff ball of wax than aux or tape etc, whole diff signal, all that they should run to is phono in on the receiver. You are using the cd recorder as a tape deck more or less, so use tape out to line in on the tdk, and tape in from tdk output. so..when spinning record, you have receiver set on phono, and the tdk should also be receiving that signal, to playback you would hit tape monitor button on the receiver and hear what the tdk has done, or is doing.
Feb 01, 2010 | TDK DA-5900 2-Disc CD Recorder
Wwhat is the sampling rate for rx v 396 yamaha amplifier
There is no sampling rate associated with this receiver. Perhaps you are asking the wrong question. What exactly are you trying to know? Sampling rates are usually associated with CD or DVD players.
Dan
May 12, 2009 | Yamaha RX-V396 Receiver
Can a turntable be hooked up to this receiver?
The Aux function is not meant for that purpose.The turntables/Record Players being way too old,now a days the amplifiers do not come with PHONO function that was specially used for playing Records/For turntables. Check if u have a phono function in your amplifier and if not then buy another amplifier with Phono function coz you need a ground wire [that comes out from the turn table] also to be attached to the amplifier and then only you can get a proper sound.
Feb 28, 2009 | Yamaha HTR-5440 Receiver
I need an owners manual for a Yamaha AM/FM Tuner receiver, Model #RX-V396 Can you help?????????
You can download instruction manual for RX-V396 from Yamaha Customer Support website, just register with your email address and download manual.
Jan 26, 2009 | Audio Players & Recorders
Connecting a Technics SL-BD20D turntable to a Yamaha RX-V463 Rece
After further research, I learned that I need to plug the turntable into a preamp before plugging it into my newer receiver. As with cassettes, record players are fading away. I ordered a preamp, but won't be able to experience success until it arrives.
Jan 16, 2009 | Yamaha RX-V463 Receiver
Yamaha Natural Sound Amp and Tape Player
All of this applies to nearly any analog consumer audio gear...
If you have any Tape Deck and an Equalizer and only the one Tape Monitor loop you should place the EQ into that Tape Monitor loop, then place the Tape Deck onto one of the probable two Tape Monitors on the EQ as it sounds like you had here...
"When I had it set up with the graphic equaliser,pressing tape monitor on the amp and on the equaliser gave me play backfrom the tape player."
That setup will allow you to apply EQ to any analog source and the tape deck in record or playback mode.
However, if you want to remove the EQ and use the Tape Deck directly on the Tape Monitor just attach the deck's Playback cables to Tape Mon In (Play) and the deck's Record cables to the Tape Mon Out (Rec). Flip the Tape Mon control to hear the tape deck or monitor it while recording.
NEVER plug anything but a turntable into the Phono. It has a preamp that expects a ver ysmall signal from the cartridge AND it also has a severe RIAA Equalization curve which would result in grossly exaggerated frequency extremes if you managedto get a non-LP source into it. Likewise, turntables without internal electronics mut always use the Phono section of a receiver, preamp or integrated amp to get the boost and EQ they need.
Mar 23, 2008 | Yamaha RX-Z1 Receiver
Yamaha RX-V396 Receiver Logo
250 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
