Question about Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A
I have a 13 cu. ft upright freezer from Frigidaire. This past week the vacuum sealer on the door does not seem to be working and items are getting soft. What could be the problem and who do I contact to fix it.
  • 311 Answers
SOURCE: Freezer not Freezing
If unit is running then it is not worth fixing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
peyton32034
  • 410 Answers
SOURCE: water in the floor
there is a drain hose that comes out of the bottom of the cabinet into a drain pan underneath your freezer take a look and see if that got pulled loose during your move. if it is in place then you most likely have a plugged drain. this can be cleaned fromt he inside at the botom. reomve the bottom basket and the shelf right above it. you will see ice build up on the floor of the freezer and and behind the cover. just defrost the ice you will uncover the drain hole flush warm water thru the line till it runs clear. good luck peyton
Posted on Jan 30, 2009
SOURCE: my freezer temp.warning light has come on and wont cool anymore.
freezer temp light stays on
Posted on Jun 25, 2009
  • 4793 Answers
SOURCE: Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Posted on Feb 22, 2010
  • 523 Answers
SOURCE: 20.3 Cu. Ft. Frost-Free Upright Freezer - White: What could be causing Frigidaire freezer to leak w...
stopped up drain,tear in gasket,not going into defrost soon enough
Posted on May 06, 2010
How cold should the outside of the door be on an upright freezer
not that cold perhaps you have a bad gasket of too much in the door of the freezer and it isn't closing properly .
Aug 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
HOW TO REPLACE THE LOCK ON AN UPRIGHT FREEZER
Frigidaire does make a metal replacement key that fits most upright freezers. Look on Parts Select. Frigidaire 216702900 Freezer Door Key PartSelect
Jul 09, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on, but the rest seemed OK. Today noticed a puddle from thawed meat. Sounds like...
I believe you freezer has sprung a Freon leak. You described it and if it changes levels is a way of measuring what Freon you have remaining. Sometimes they can be repaired it depends on how they were built. Hope you did not loose much food, Sea Breeze
Mar 21, 2010 | Frigidaire Freezers
If the defroster unit is bad ,is it dangerous to let the freezer run? possibly a week?
It's not dangerous ,you jusi have to defrosted manually by unplugged and let it defrost about once a week.
Sep 24, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer vaccum seal not working
check the gasket and make sure that it it not pinched and letting in air whe the door closes. primaryly around where the hinges are.;
Dec 27, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A Logo
20 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
