Question about Mitsubishi WS-55511 55" Rear Projection Television
Where do i connect black probe on my multimeter to check for 12v dc on pc9a21 on ws-65511 tv
    Genius:
  • 1,112 Answers
Hi:
You can place the neg probe any where there is a ground or metal connection. Try placing it on a metal sheild of one of the boards.
Posted on May 22, 2011
How to fix may motherboard if the 4pin had pluged it doest work?
Multimeter positive (Red) probe lead, connected to Yellow wire pin, and negative (Black) probe lead of multimeter connected to EITHER Black wire; do you read 12 Volts DC?
Test the other Yellow wire. 12 Volts DC from it too?
Post back in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Gigabyte GA-MA780G-UD3H Motherboard
Tip
Bypass Mitsubishi WS-65511 Front Lock
Bypass Mitsubishi WS-65511 Front Button Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65511 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65511 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
________________________________________
Mitsubishi WS-65511 Manual Download
Reset Mitsubishi WS-65511 VChip Password
on May 03, 2010 | Televison & Video
Tip
Bypass or Reset Mitsubishi WS-65511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65511 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
My lights on my trailer wont work. How do I test the power that goes from my vehicle connector to the trailer.
Hi, 1.connect the trailer connector to the vehicle connector. 2. Make sure your tester is on DC volt selection. 3. Take black test probe (usually negative) to the frame of you trailer. (You want to have a good contact with metal so you'll be able to get a good negative polarity; no rust or paint between the test probe and the metal.) 4. Turn on lights and check the DC volt between the metal frame of your trailor (black probe) and the wires which goes to the lights (red probe).
...if you got voltage (12V or 24V depending of your system voltage) it means that the bulb is gone. (you should have 12V or 24V only on one (1) wire). If you do not have any voltage on one or other wires it probably means that you got cut wires... It might be the case if it was working before.
If its a new installation make sure that voltage is coming out of the plug. (you do the same test but you place the negative probe on metal from vehicle and the red probe into the pins of the connector.)
*** In a DC system we usually get Red as Positive (+) and Black for Negative(-) ***
hope it will help
best regards
Jul 11, 2011 | Gb Electrical GET-213A Heavy-Duty 4-Way...
Does not switch on
Unplug the TV. Carefully remove the back cover of the TV. Check continuity of the mains cord-Not ok-replace the cord-ok-Connect mains cord to the wall plug and switch one, take care not to touch exposed parts to avoid electric shock, which could also be fatal, connect the multimeter across the leads soldered on to the board and ensure that AC is in. Check secondary power supply of the SMPS for appropriate voltages (say 24V, 12V, 5V, 7V DC etc.). If that is ok, the problem lies in the board. You may have to go for a schematic of the TV and trouble shoot. In my opinion, the problems might be in the power supply. Once that is set right, check for shorting of DC supply to the TV using an analogue multimeter, setting to x1K Ohm. If reading shows low ohms or short, on checking up with red probe to positive and black probe to negative and vice verse, there is/are components shorting in the main board. You may have to check the components using your multimeter, ie., COLD TEST.
Feb 09, 2011 | Panasonic TC-32LX85 LCD TV
Tip
Download Mitsubishi WS-65511 HDTV Manual
Have you misplaced your Mitsubishi WS-65511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
HDMI upgrade card available?
No,it for data recovery mainly.Ur HDMI connection it work?If not tries another HDMI cable usally work.
Apr 11, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Tip
I hope that helps.
Tip
I hope that helps.
Mitsubishi WS-55511 55" Rear Projection Television Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
